Results 1 to 5 of 5
Thread: 1uzfe correct flexplate assembly?
    Dec 2012
    Wellington
    Default 1uzfe correct flexplate assembly?
    Just fired up my 1uzfe mx73 for the first time and there was a horrible grinding noise coming from the trans, was told I maybe have installed the flex plate and spacers wrong , the order I did was CRANK -THICK SPACER -FLEXPLATE -THIN SPACER WITH CURVED EDGE, which I'm sure was correct? Can anyone please show a photo or diagram of how it is supposed to be?
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Default Re: 1uzfe correct flexplate assembly?
    Unfortunately no pics for you. Is it possible the flex plate is on backwards? I can see the starter getting caught in the ring gear as I believe the teeth are angled slightly. Your spacing seems correct but i could be wrong as i haven't played with any uz engines yet so that info is from other autos I've played with.
    Hope this helps.
    Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
    Dec 2012
    Wellington
    Yeah I am pretty sure it was the right way , ( angled tooth side facing the starter motor) , but I just took everything off and flipped the flexplate to see if that works
    I have this drawing I did ages ago.
    If you haven't already, start it with the gearbox off?
    Rules out the gearbox and also lets you see where it's touching if it is.
    Dec 2012
    Wellington
    Yeah we'll by the looks of that diagram I got it right will start it when I get some new igniters
  1. How do I correct my SpeedO.
    By mux in forum Tech and Conversions
    Last Post: 27-09-2007, 04:25 PM
  2. where to set the dot to get correct TDC
    By slide86 in forum Tech and Conversions
    Last Post: 31-03-2006, 07:22 AM
