Align the Blue dots
ok, so there is another post just below talking bout engine TDC. i dont need to know that. i already have the engine setup at TDC.
What i do want to know is, do i align the dot and the mark before i insert the crank angle sensor to provide TDC for the sensor....
OR
do i have advance/retard it a tooth so when i put it in it lines up the marks when its installed. ill have to remove the rocker cover to see it tho.
which is right.
a pic to show which marks i mean (Click to enlarge)
Originally Posted by The Witzl
Align the Blue dots
Current Toys
97 Pajero EVOLUTION
04 Lexus ES300
92 Hilux 2wd
Dont align thedots at all, One of the teeth on the wheel is enlarged. In that pic it looks like it is the light coloured one to the left about 2 teeth over from what 1200det marked.
This should be aligned with the notch on the body, which slide86 has marked in the previous post.
The holes are to let oil in.
EDIT:
mmkay. im looking pretty hard, im not seeing a tooth thats bigger. its sitting right in front of me. i think that one in the pic looks bigger cause of the flash. i cleaned it all up and they all look the same......
maybe im just blind?!?!?!?
Thanks for the feedback , When i rebuilt my 4AGZE i could have swore i used the holes but then again that was a while back i may have used the notch
Time to double check , I better remove the pic![]()
Current Toys
97 Pajero EVOLUTION
04 Lexus ES300
92 Hilux 2wd
Obviously there are some different dizzies ?
Current Toys
97 Pajero EVOLUTION
04 Lexus ES300
92 Hilux 2wd
What engine is it from then? Both of mine have the longer tooth. They are smallport GE and GZEs
mines a bigport gze. i figured it out by removing the cover and looking at where the thingy (damn whats the word) is pointing. i could figure out where it should be when engine is at TDC.
just like pointing the rotor button at No.1 cylinder when putting a dizzy back in
How could you have a larger tooth on the dizzy , Wouldnt that bind up on the exhaust cam that its running off when rotating.Originally Posted by takai
Current Toys
97 Pajero EVOLUTION
04 Lexus ES300
92 Hilux 2wd
Not at all, when i get home tonight from work ill take a photo for you.
