Results 16 to 30 of 33
Thread: 5ME head bolts
    Default Re: 5ME head bolts
    Are you sure there isn't any massive air pockets? That'll make temp gauges read all sorts of stuff.
    Junior Member Domestic Engineer mic*'s Avatar
    Quote Originally Posted by JustCallMeFrank
    True.
    Make sure you do a comp test before pulling it apart again.
    meh...
    Properly bleed the cooling system of all the air. Then if it still does it, go get a Teekay test. If it still does it, go buy another 5ME
    Drop the 7M in there!
    M4D Crown skids!
    its rather puzzling.. the signs are a little mixed..
    hopefully matty will reply to this thread and offer his opinions on what he's seen.
    Its certainly running like a dog now - so I think the cheaper/easier option would be just to find a wreck with a running 5ME as nathan suggested and plonk it in.
    Damo
    W.A.
    Quote Originally Posted by WA_TRD_83
    Damo
    obviously we were doin it the cheapest way possible, hence the liquid steel. But we did use a new head gasket
    Nathan i did a TK test and bam blown headgasket, thing is it never overheated once in my car as it was only blown between cylinders.
    My guess is that when we cleaned the water ports in the head (so the liquid steel would hopefully stick) it brought the water port just that little bit closer to the combustion chamber, then i think the liquid steel has not held on and come away from the head and causing the leak.
    Damo i've had a couple more idea's today after diagnosing a blown head gasket at work today.
    1. we should take out plug number 6 and see if the rad still pumps water out when she is runnin (im pretty sure number 6 is gunna be the culprit)
    2. we should take out plug number 2 as this was the other water jacket we liquid steeled, and try the same thing.
    3. if this is the case i reckon we should run it with no water at all, fuck i mean V dubs dont use water hehe
    We should also see water mist comin from the 2 blown cylinders with the plug out aswell.
    Still doesnt fix the leak though.............F%CK
    Charge the battery playa, we'll do a couple of conclusive tests.
    Matty
    Throw it in the bin and replace it
    I can get you a cheap 5me with a rod knock, just use the head off that.
    could be interested.. send me a PM with the details..
    Damo
    W.A.
    ahh fuck not the head swapping game again. We cant be certain my block is still good
    got any without a knock?
    Matty
    Did you put a straight edge over the block before you put the head back on?
    W.A.
    yeah it was pretty bloody good though. The head was a touch out between cylinders.
    I thinks it obvious what has failed, being the liquid steel.
    Damo i think we should go look at another crown instead!!
    Matty
    MS123 - Quokka - $500 - Jarrahdale
    W.A.
    already rang bout that one..... Was gunna tell you bout it, except it has one front hub assembly gone and one rear hub assembly gone. I assume you want a pair hehe
    Matty
    Damo's car has spare hubs, use those.
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. 4AG 20V Head Bolts
    By psychofox in forum Tech and Conversions
    Last Post: 29-04-2006, 01:55 PM
  3. 2T-G head bolts or studs - availability?
    By SeptemberSquall in forum Tech and Conversions
    Last Post: 19-12-2005, 10:13 PM
