Results 1 to 4 of 4
Thread: Chassis Straightning on the cheap RA23
    Junior Member 1st year Apprentice mattlock's Avatar
    S.A
    Default Chassis Straightning on the cheap RA23
    Hey all, i need a cheap way to straighten a slight twist to my chassis it is twisted on the LHS arond 5-10mm towards the right and is pushed in around 20mm on the left, all panels still line up but the front LH wheel is 20mm closer to the rear of the front wheel arch than the right side, ive got the wheels aligned but need it pulled out on the left a bit, can anyone give me a hint without going to a chassis align machine and getting charged a small fortune as i just killed 1 of my Custom$3500 3 piece Liniaretta wheels, i used to just chain my old dungers to a tree and hit reverse but ive grown up a little since then, it is only a slight twist so maybe a panel puller once all the front end is removed?
    HELP NEEDED, i was just about to do a full ground up resto and is bad timming, now all my rebuild cash is going into getting it straight damn it!!!! or im looking for a 23 bare shell if anyone knows of one in Adelaide or at least Australia
    Cheers all.
    Matt
    PH 0403764718
    Feb 2010
    Auckland
    Default Re: Chassis Straightning on the cheap RA23
    you could try pulling on it with a block & tackle, and then use an oxy torch to heat the bent area.
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Quote Originally Posted by Stolic View Post
    Don't heat it it'll weaken it
    Apr 2007
    I second the dont heat it, all work seems to be done cold, but really if its that far back & twisted in my opinion it should go on a rack & be properly supported & pulled only enough as needed ..
    No insurance ??
  1. Ra23 chassis tie bar
    By GeeB in forum Tech and Conversions
    Last Post: 09-06-2008, 12:39 PM
