Results 1 to 6 of 6
Thread: Wiring r34 TPS onto 2jz jza80 loom
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default Wiring r34 TPS onto 2jz jza80 loom
    Hey guys,
    Have almost finished my 1.5jz project using a jza80 loom
    Will be using an after market 90mm throttle. Which for
    1. The rotating director was different
    2. Wouldn't work without an adaptor
    Have bought a r34 TPS, fits and rotates spot on. Just not sure how to go about wiring it?
    Have done some research but none overly helpful
    I had it previously wired to my 1jz loom but that is long gone now
    The jza80 loom has 2 TPS plugs one for traction control
    87' z20 Soarer - 1jz Gt35r -
    Nov 2011
    Default Re: Wiring r34 TPS onto 2jz jza80 loom
    i think the pink is power 5v
    white is signal
    black is ground
    these tps dont have idle wire so if u are running aftermarket ecu u will be fine
    get a multimeter and check resistance from black and pink as u turn tps resistance wont change
    then check resistance from black to white resistance should rise
    then check resistance from pink to white resistance should drop
    TAS
    next problem is the jza80 loom has two TPS plugs
    Both plugs the same colour wires except one has a blue w/ red wire and the other has a red w/ blue wire
    I'll be running a standard ecu, will I have problems without the idle wire?
    Yes, you'll have problems with idle without the idle wire.
    The ecu won't know when to engage the idle map, and the idle speed control valve. You may find that you'll to bump the idle up a few hundred rpm to stop it from stalling. It will be trial and error.
    As for wiring, get a multimeter out and work out what each pin does. Should only take 15 mins.
    Nov 2011
    just google jza80 wiring diagrams
    heaps out there
    find out which wires are for tps
    anyway the tps that sits inside closest to centreline of motor is proper tps
    and tps plug that goes on outisde is for trac
    one end of the plugs will have brown wire this is ground
    next wire in is idle contact
    next wire is is signal
    next wire whihc is last one opposite side of plug to the brown is 5v power
    TAS
    If anyone needs help for the future:
    WIRING WITH NISSAN TPS (when using an aftermarket ECU):
    If you decide to reuse the Nissan TPS sensor that came with your used Q45 throttle body here is how to wire it up.
    Nissan Q45 TPS sensor wires: Red - 5 volt input White - TPS signal Black - sensor return
    ToyotaTPS harness wires: Blue/Red stripe - VC 5 volt supply Yellow - VTA throttle position signal Brown/Black stripe - sensor ground
  1. 3T-GTE wiring loom loom
    By camshere in forum Tech and Conversions
    Last Post: 31-01-2011, 12:53 AM
