Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 219
Thread: Wakefield Park Track Day - Friday 10th of May!!
  1. #166
    Default Re: Wakefield Park Track Day - Friday 10th of May!!
    I think it's the T50 bellhousing, extractor clearance and the 12:1 comp ratio causing fitment/ability to crank issues
  2. #167
    Oct 2009
    Half decent reduction jobby should do the trick, how many times does it get started a year?
  3. #168
    I thought he was running a stock starter. Suddenly their "park it on a hill or push it every time" advice for Peter/mr2360 doesn't sound so exciting? There's two of them too, what's the problem?? Just take turns push starting it.
    Toymods Club Member
  4. #169
    Jul 2007
    What's up with this weird starter arrangement on the spoontah?? Shirley it's just a 4A starter, which is like every other starter ever attached to a 4A? Even the different versions are usually swappable aren't they? Particularly if you have extra clearance with extractors? I could offer a smallport reduction starter sitting at Elanora, but it's been sitting there a long while and is a bit corroded in places so i can't guarantee it works... or fits from the sounds of it?
    Have updated the first post with cars.
    No, it is not interchangeable, at least not with the one off my E51 gearbox. The bolts to the bellhousing are spaced differently, and the starter itself is a different length, so you cant swap housings over (we tried)
    Looking like hocker is out, my sources have come up with nothing... but I will still come down on my own at least yes.
  5. #170
    Oct 2009
    Farking go get it fixed?
  6. #171
    loves hi RPMS Backyard Mechanic
    Quote Originally Posted by whatthe? View Post
    yep.
    this is the 4th one ive broken. last one i dunno exactly what happened as it happened while it was getting tuned, previous to that i snapped the shaft clean off.
    ive got enough charge going to starter, just not a capable starter to crank it. it mostly the kickback from having to crank it that does the damage.
    we had some fun trying, and then realised that they are different lengths. ghaids.
    also as it hasnt been run (apart from being started once start last saturday) since nationals as ive been busy doing other stuff. im going to a motor khana next weekend (to stick it up some evos and WRXs) so i will get my motorsport fill there. BUT i will be back for august and will be trying to do eastern creek between now and then.
    i do appreciate all the encouragement and not giving up though gents, its just this time its not meant to be.
    N/A for life...
  7. #172
    OK - Vito/Nick - What time for Brooks Rd meetup? Anytime is fine for me
  8. #173
    Oct 2009
    7-ish?
    Fucking couldnt get the front camber, something is screwed with my right hub or something.
    Anyway, camber tops maxed out, running a shade under 2deg on the front with 2.5deg on the rear lol
    Should be interesting tomorrow, bit pissed but I did leave it late
  9. #174
    7 is fine for me. Unless Vito has an issue let's lock it in
  10. #175
    Jan 2008
    No luck finding whats going on with mine.
  11. #176
    Jul 2007
    I wont make brook's rd. Finish work at Dural at 5:30 and then I need to go find my CAMS license and other related shit before coming down. I cant seem to find my L2S since doing toyota nationals, fucking hope I havent lost it.....
  12. #177
    Oct 2009
    Ignition switch
    Relay
    Starter solenoid
    Tried to start it jumping 12v directly to the solenoid? Remove the relay in the fuse box and stick a hot wire in the pin
  13. #178
    Jul 2007
    just remove the cap off the starter relay and push the contacts closed by hand...
  14. #179
    OK maybe we should scrap the Brooks Rd meet and just meet at the motel. If you guys give me a call when you're nearly there I'll let you know the room numbers. 0439 848 359
    At least I can head down early and miss the traffic on Pennant Hills Rd this way (and have a few bevvies whilst i wait )
  15. #180
    Oct 2009
    Sliced my hand open trying, grabbed wire instead haha
  1. Wakefield Park Track Day - Friday 8th of March!!
    Last Post: 15-04-2013, 06:27 PM
  2. Wakefield Park Track Day - Friday 9th of November!!
    Last Post: 01-02-2013, 09:07 AM
  3. Wakefield Park Track Day - Friday 7th of September!!
    Last Post: 03-10-2012, 04:36 PM
  4. Wakefield Park Track Day - Friday November 6th!!
    Last Post: 04-01-2010, 01:10 PM
  5. Wakefield Park Track Day Friday 2nd of November!!
    Last Post: 06-02-2008, 04:22 PM
