Re: 1uz help needed
unplug the inhibitor switch and take for a drive
also check which wire has power on the inhibitor when ign is on and unplugged
should be red/blue trace wire
Re: 1uz help needed
Well, I'm officially a dickhead now. Part of my rewire involved reconnecting the reverse lamps because I didn't like the plug were it was so I removed the plug and soldered the wires and taped them into the loom.
Guess what I did. I had two wires, red/white feed to reverse lamps and yellow which is an ignition power feed. I connected the yellow wire to the red/black feed wire from the inhibitor switch. So the ECT thought it was in reverse all the time. I cut that wire and now it all works perfectly. Now I can solder the right wire up and re-tape the loom.
Cheers, guys. Thanks for your input.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
