Results 16 to 18 of 18
Thread: PITA MKiii that wont crank over
    Nov 2007
    Default Re: PITA MKiii that wont crank over
    See if you can get hold of a early JZ series starter they are much powerful. I swapped mine to a JZ series one. Just the STA signal connector is different easy fix tho.
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    I pulled my starter apart today, they contacts in the solinoid that passes the current to the motor are very badly worn and I would say this is probably the problem why mine wont start, it would be worth you pulling the cover off the end of yours and inspect it, its only 3 bolts
    Deadly Vehicular Assassin Automotive Encyclopaedia Impurist's Avatar
    Jul 2010
    If you search on google for "mk3 starter relay mod" you'll see a bunch of guides that should be helpful with this problem.
  1. Replies: 36
    Last Post: 23-04-2007, 03:28 PM
  2. Why wont my engine crank fast?-FIXED!:D
    By WHITCHY in forum Tech and Conversions
    Last Post: 17-01-2007, 09:42 PM
