Results 1 to 8 of 8
Thread: JZX100 auto speedo won't work?? Please help...
    Jan 2009
    Default JZX100 auto speedo won't work?? Please help...
    Hi. I have a Toyota surf, which I've put the whole 1jz vvti auto, wiring, etc, out of a jzx100 into it. The problem is the speedo won't work. I've had a auto elect look at it, but no help. If anyone has any ideas, please let me know. Thanks
    Default Re: JZX100 auto speedo won't work?? Please help...
    apprently they burn out a resistor on the back of the speedo which will cause it not too work , my surf doesnt work some times but the trip meter and odo will turn over still
    you tried another cluster??
    cheers luke
    May 2010
    Moscow
    To run 100% factory speedo system for jzx100 engine, you would need abs/trc computer and all 4 wheel sensors installed and properly connected to engine/transmission ecu.
    On my conversions, I install a speedo converter. I know there's quite a number of them available in your area.
    Nov 2011
    Which auto elect did u take it too
    I can look at it if u want to pay for someone that deals with jap wiring day in day out
    as I have all the wiring info for the jzx100
    When u say u fitted all the wiring from the jzx
    What do u mean
    All behind the dash is that jzx
    Or did u just wire in the engine loom into the surf body loom
    Is the speedo the jzx or is it the surf
    It's hard to understand how u went about it
    Jan 2009
    Yeah thanks guys. I think George is on the money. That I don't have the wheel sensors, etc. I have use the whole wiring loom, engine and dash and the speedo cluster out of the jzx100. I might just have to use a speedo converter.
    Nov 2011
    easy way to tell if it uses the abs is check on back of gbox and see if there is 2 speed sensors
    u might have one speed sensor only
    if so use a converter on this sensor to drive your speedo
    or get a gps converter
    or a gps speedo
    Jan 2009
    After a quick look. I see one black sensor on the passenger side rear of the sloshbox. With a green and red wiring running to it. Is this what you're talking about?
    Nov 2011
    No those two wires are for the auto to change gears
    It's the output shaft speed sensor
    U now need to see how your speedo works
    If it needs just a square wave input just
    Get a speedo box to go from the two wire output shaft sensor
    To the speedo
  1. JZX100 V's MX83 auto Q's
    By TTMX83 in forum Tech and Conversions
    Last Post: 31-01-2011, 08:42 PM
  2. Replies: 6
    Last Post: 20-06-2009, 02:50 PM
  3. ae82 speedo doesn't work
    By supra_cam in forum Tech and Conversions
    Last Post: 06-07-2008, 10:54 AM
