Results 1 to 5 of 5
Thread: ae82 speedo doesn't work
    Junior Member Grease Monkey supra_cam's Avatar
    tasmania
    Default ae82 speedo doesn't work
    I've found a cheap ae82 with a manual 4ac that I might be buying as a daily driver. Its only problem is that the speedo does not work, it just sits on zero. Is it very hard to get the speedo working again? I'm not very familiar with these cars
    cam
    Default Re: ae82 speedo doesn't work
    If it's like the AE92 (I'm assuming it is) then the speedo cable will run out from the firewall into the gearbox (somewhat thick and firm cable). It should have a screw-on join about halfway along, unscrew that and the end on the gearbox and check it's not broken. It's not uncommon for the speedo cable to break on the lower section due to a lack of grease (they are designed to spin the grease up the cable so can dry up below).
    tasmania
    thanks Talasas. Also is there an online service manual for 4ac's, kinda like the mkIII tsrm for ma70's?
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    May be something in this thread for you.
    http://www.toymods.net/forums/showth...4078#post14078
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    Aug 2006
    success 6164
    the ae82 is a single cable..it doesn't separate like the ae92 one does at the firewall.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    By The Witzl in forum FAQ
  2. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
