Results 1 to 6 of 6
Thread: Importance of an oil pressure sensor
    Dec 2012
    Wellington
    Default Importance of an oil pressure sensor
    I have nearly finished my mx73 1uz conversion, just got a front mounted oil filter setup but the pressure sensor hits the engine mounts, without it it will all bolt up sweet, just wondering if I really need the sensor or if I can modify it with a fitting to relocate it to the other side , any help
    Act
    Default Re: Importance of an oil pressure sensor
    as long as you have an oil pressure sensor in the pressure side of the system you should be fine
    Oct 2009
    Quote Originally Posted by Jonboy1uz View Post
    Nope, put a plug in it and carry on.
    Its just a moron light that triggers at 5psi, if your giving it the beans and you suddenly lose all oil pressure the motor is fucking rooted by the time you see it, process what it is, pull over and shut down kinda thing.
    Melbourne Victoria
    or run a braided line from it to the strut apron then buy a vdo oil adjustable oil pressure light and set it up to come on at 200 kilopascals and use the other side for a mechanical oil pressure guage
    Oct 2009
    Another option would be to buy a $30 sandwich plate.
    Aug 2009
    Buy a 90 degree fitting. Most of the auto parts stores usually carry them. Then screw it in so switch faces away from mount, or better still get oil gauge and sender set.
  1. Timing belt tensioners - importance of replacement
    By Mos in forum Tech and Conversions
    Last Post: 20-06-2007, 05:46 PM
