Page 6 of 6 FirstFirst ... 456
Results 76 to 84 of 84
Thread: 1GGTE - 3SGTE cam gears <- On the verge of a break through, looking for guinea pigs
  1. #76
    Default Re: 1GGTE - 3SGTE cam gears <- On the verge of a break through, looking for guinea pigs
    Quote Originally Posted by Lambolica
    if you look closely at the factory cams you will see that they are adjustable buy Approx. 3 degrees each way. but placing them on different locating pins.
    Prolly no where near as good as the adjustable flavour but possibly helpful.
    Simon
    do you know which way is which? the cams are set standard on the center pin, if you move the cam gear clock wise (looking FROM the front of the car), will that advance or retard it?
    EDIT:
    just had a thought.... what if you were to get a set of aftermarket 3S gears then change them so the center is infront of the outside rim. this would change the offset, by how much would depend on the brand, but may eleminate the need for such a large spacer, if a spacer at all... only concern would be that the center would have the threaded section of hole, so you'd need to fasten them from the reverse side of the gear.
    '77 RA28LT #2 ← 2.2L 18RG...
  2. #77
    or just buy these??..... sliding is overrated.. it's marginally easier to setup on the dyno.. but at all other times, solid is better (imho) (edit:, they are 3S ones http://page8.auctions.yahoo.co.jp/jp/auction/h36127310 )
  3. #78
    well... what spacing are the dowel holes? what are they worth?
  4. #79
    just doing a bit of thread necromania here i know, but i picked up my 7M last night, and i noticed the cam gears on that looked remarkably similar to the 1G ones, i did a quick count and from memory i got 47 teeth, the 1G and 3S had 46, so perhaps i can't count, but maybe the 7M gears are the same... though from memory the 1G has the deep side of the dish forward, the 7M had the shallow side... can anyone confirm?
  5. #80
    1g have the deep dish side forward yes
  6. #81
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    Just seen this thread... just to confirm if you guys didn;t work it out yet the 1G adn 3S cam pulleys are exactly the same, -they have the same toyoata part number, as someone correctly identified, they fit on one engine one way, and on another engine the other way...
    I'd love vernier pulleys on my 1G
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
  7. #82
    for all that dont know heres the easier option, and probably cheaper than having to redo a head after fucking it up....lol
    FORCEFED PERFORMANCE adjustable 1GGTE cam gear.....n they come in pretty colours
    http://www.toymods.net/forums/showthread.php?t=11755
    blake
  8. #83
    oh and depending on the motor S or G.... the letter G faces OUT on a G series engine....(as stated b4) ans the S faces out on a S series engine...
  9. #84
    Thanks Blake....
    Karma Supra : If you are interested in a set of vernier gears for a 1G, follow the link a couple posts above. I can have a set done and sent to you in the UK if you really want a set.
    CHECK IT OUT HERE
  1. 1GGZE SC on a 1GGTE?
    Last Post: 22-06-2006, 08:15 PM
  2. 4agze questions
    Last Post: 14-06-2006, 09:50 PM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 01:29 PM
  4. 4agze conversion
    Last Post: 02-03-2006, 09:52 PM
  5. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 08:10 AM
