Results 1 to 5 of 5
Thread: KE30 4K Issues!
    Corolla Collecter Backyard Mechanic Trent-KE30's Avatar
    Default KE30 4K Issues!
    Hey there,
    I have a KE30 that i put a 4K and 5spd into not that long ago but there seems to be an awful lot of blow by. After a long drive there is all oil coming out of my spark plugs and it looks like oil is being pushed out of the head and leaking all down the back of the gearbox
    Now I generally thought blow by was compression getting past the rings and forcing its way into the head correct?, Is there any other way to fix this rather then bite the bullet and replace rings etc..
    Gimme some ideas..
    Trent
    1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
    1987 Ford Falcon XF S Pac
    My Missus is a Domestic Engineer BradW's Avatar
    Default Re: KE30 4K Issues!
    Is the pcv working correctly. Sounds like the crankcase is pressurising instead of venting via pcv.
    Brad
    Old Corollas never die...
    My KE30
    Hmm I know the pcv is connected but wether its working properely is another thing, ill check that out, thanks Brad!
    Trent
    Hoppers Crossing
    trent rather than plumbing back just go for a drive with it vented to atmosphere and see if it helps.
    Ok I just pulled it off then and it wouldn't idle, as soon as i put it back on it idles fine again.. There was a fair bit of black shit in there that i cleaned out..
    Ideas?
    Trent
  1. 20v into ke30
    By DryftKult in forum Tech and Conversions
    Last Post: 21-08-2006, 12:03 PM
