Results 1 to 12 of 12
Thread: Toyota ZZ series engines north-south RWD
    Default Toyota ZZ series engines north-south RWD
    You wouldn't believe how hard it is to search for things with less than 4 letters...
    Looking for a solution to north-south RWD gearbox for a 1ZZ/2ZZ...I'm sure it's been done, but buggered if I can find any info!
    -RM
    Default Re: Toyota ZZ series engines north-south RWD
    locosts and clubmans?
    Junior Member Backyard Mechanic manny's Avatar
    You can try and make your own like I did a few years ago, in this case a 1ZZ to a J160
    http://mannylocost.blogspot.com/2009...x-adapter.html
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Of course: the idea is still thriving! It does look like a blacktop/silvertop would be MUCH easier, bang for buck, and leave sufficient room for a ZZ swap down the track...
    3SGE BEAMS Blacktop?
    Problem with the 3SGE is the height: they're very tall, and the sumps hang down quite low, so they become a problem. Plus they're a heavy engine for a 2L!
    Jul 2009
    How about a 1MZFE
    Not enough revs Don't want a torque monster!
    At this stage it's looking like I might just go for a blacktop 20v for the mean time, and make sure I leave enough room in the frame for a ZZ if I decide to go that way later...
    there is not a lot of difference between the 4A and the 2ZZ in terms of size.
    the 2ZZ is a taller head to deal with the rockers for the valve lift system but the length and width of the engines are pretty close.
    also worth checking out these threads if you already haven't
    http://www.toymods.org.au/forums/tec...-into-rwd.html
    http://www.toymods.org.au/forums/tec...-2zz-help.html
    Doesn't Billzilla have one in his clubman?
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Junior Member Grease Monkey rick q's Avatar
    Bill has a BEAMS in his Fraser Clubman, though I believe there are two other Fraser's in Qld running 2ZZ's north south
    Cheers ..... Rick Jones
    Fraser Clubman
  1. North/south mid-engine transaxles...
    By mullett in forum Tech and Conversions
    Last Post: 13-10-2006, 11:40 PM
