Results 1 to 15 of 18
Thread: Help needed- 4runner not starting
    Junior Member Grease Monkey MorgzMods's Avatar
    Aug 2011
    Default Help needed- 4runner not starting
    Hi all,
    just serviced the 4runner (4Y-E) and I've replaced the following:
    starter motor
    water pump
    plugs
    plug leads
    battery terminal connections + negative lead to chassis and engine block
    all fan/alternator belts
    and I'm doing oil + filter and coolant next.
    The issue is when I put the key in the ignition and turn it to 'on' I can hear two clicks, they don't seem to be coming from the starter motor or alternator, more near the intake manifold. When I then turn it further to start the engine I get a slight dimming of dash lights and nothing else.
    I've checked my connections everywhere I can think of, the battery was fully charged when I started the service and had the negative terminal disconnected. I'll put a battery charger on it now and see if that makes any difference at all.
    Hoping somebody can offer some advice
    Nov 2011
    Default Re: Help needed- 4runner not starting
    EFI rely has died
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    Aug 2011
    is that the same as the fuel pump relay?
    I'm having a look at switches and relays for the 4YE here and over the next page, but it doesn't jump out at me
    Thanks for the reply!
    EDIT: is it 85915A?
    Oct 2009
    Are you getting power to the starter solenoid and is the battery charged?
    Aug 2011
    Battery is charged to at least 80% using a decent charger, I haven't/am not 100% on how to test power to the starter solenoid (other than the leads/plugs connected - which they are)
    What's the best way?
    edit: when the key is 'on' and I have the interior lights on, trying to start the engine dims the lights. so that should mean power is getting to the starter right?
    Oct 2009
    Get a helper to turn the key while you have a multimeter on the terminal, if you get 12v and the solenoid engages then your doing alright. You either have some sort of shitty lead from the battery, the battery is fucked or your new starter aint so flash. If you get nothing then check the work backwards. Starter relay, fuses, ignition barrel etc
    Aug 2011
    Sweet, I don't have a multimeter on me at the moment, but will test that tomorrow in the morning.
    If i don't get 12v on the starter and I want to check the main power cable is it as simple as running one of these from position to the starter? or does it need to run through a fuse? I have just replaced the terminal connectors and I wasn't happy with the look of some of the postive leads.
    or even if it's just to test that it isn't the wiring that's currently in place
    http://www.swannelectronics.com.au/P7230022.JPG
    Oct 2009
    Run it direct from the battery
    Aug 2011
    just throwing it out there you replaced the starter how do you know it's not a dud?
    Aug 2011
    thanks dneg, I sent a PM with a few more questions.
    and sc400, other than hoping it's all good because it's new - I don't. I wasn't aware exactly what it did until watching a youtube video, should I of tested it like this:
    Youtube Link
    embedded video:
    Aug 2011
    The starter motor I bought is dud, worked once after we pulled it out and bench tested it before not responding again at all. So we pulled apart the old one, cleaned it up, got rid of stray bits of metal and tested it again, working perfectly.
    So now she's back in the car, it cranks but won't start. Battery is OK, tested old leads and new leads, new plugs, tested old plug in cyl #1, loosened the top of the fuel filter (newly installed) and there's plenty of fuel (and pressure)
    All plugs are connected as far as I can see.
    Nov 2011
    Check for spark on all cylinders
    Check spark timing is ok
    Then spray something flammable down butterfly
    If it nearly starts or starts then u have fuel issue
    Check basics
    Aug 2011
    Thanks dumbass! (feels weird typing that)
    I ended up checking all the connections and shit again, then checking all the fuses one by one. I decided to see if it wouldn't even crank without the 'main relay' and it started. so after checking that it wasn't a fluke I put the relay back in and she still goes.
    when should I see a significant increase in my oil pressure gauge? idling it doesn't seem to move from low. I haven't driven it anywhere yet though, still checking I've got enough oil in there.
    Aug 2011
    Quote Originally Posted by MorgzMods View Post
    oil pressure should come up just after the engine catches also dependent on what weight oil you use oil temp and whether gauge is mechanical or electric
    Nov 2011
    hilux oil pressure gauges are the worse toyota has ever made
    if engine sounds ok when u start it then dont worry bout it
    at end of the day by time u see an oil light come on or oil gauge drop to 0
    and your on the freeway yr engine would most prob be close to fkt hehehe
  1. 1uz into v6 4runner.
    By blurunner in forum Tech and Conversions
    Last Post: 03-02-2012, 07:04 AM
  2. 4AGE not starting correctly 5-10 times, then starting correctly?
    By phrostbyte in forum Tech and Conversions
    Last Post: 30-01-2006, 06:55 PM
