Results 16 to 30 of 41
Thread: ke70, Holden ecotec conversion
    Feb 2012
    Australia
    Default Re: ke70, Holden ecotec conversion
    Yeah, I came to my senses... Celica with a Buick engine is a No No.
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
    Nov 2007
    The Good thing is once you get it converted and have had a bit of fun
    You can raise the bar by finding a Supercharged Ecotec and dropping that in.
    Aug 2011
    i can understand your thinking if it ever goes pop ecotec's are easy and cheap to get but i would at least keep it in the toyota family
    Nov 2011
    Quote Originally Posted by sc400 View Post
    Well in a way he would be.. Toyota Lexcen?
    In the early '90s in NZ I knew a guy who had a TE71 with a small block chev in it. On the same side of that coin I also knew a guy that had a mark 1 Escort with a 265 Valiant motor in it and another who also had a Mk 1 Escort with a P76 engine. Then the 1UZs started coming thru so that was all on. I at the time owned an SL/R5000 Torrie and had a hideously worked Mini for a daily drive. While I do regret selling the Torrie the most stupid thing that I've ever done was to sell the Mini. Yet that daily did get replaced with a "Tickled" EE90 Corolla. I lent that to a friend while I was away on holiday and never got it back. Did get some coin back tho. Well while some of us do not agree with his engine choice it is his car and he can do what the hell he wants with it. But he also does need to do the research to see what it would bring to him should he ever wish to sell it
    His. 2005 GRJ120 Prado VX
    here is a thread with some info in it:
    http://www.ae86drivingclub.com.au/fo...read.php/23385
    Sep 2012
    man... most of you guys are on the hate.
    so to all the guys that like the idea. heres the progress.
    both have cable clutch so thats easy.
    rear box mount is in the same position, give or take 20mm
    commodore radiator will fit. gaining thermo fan
    engine mounts very close.
    sump is front drop nice alloy setup fits strait in.
    also i met a guy at the drags running 11s with a turbo 3.8 street driven corolla.
    Feb 2012
    Australia
    If you do it, Document the build here, I'm interested in seeing how well things go
    Aug 2011
    +1 for the build thread one little trick i know with ecotec is too make a 1" spacer and put it between the two half's of the inlet (top and bottom)to give a tickle the bottom end torque
    80's stylin Domestic Engineer Sammich's Avatar
    May 2007
    don't worry about the haters, its the internet.
    still a cool/interesting/different build regardless. Those ecotec motors have a butt-load of midrange torque so it should be a laugh to drive, even if the handling is somewhat compromised. And plenty of replacement parts if it ever goes pop.
    MA61 + 5M-E POWAZ: sold :'( | MX73 + 5M-GE: asploded. RIP :'( | MA61 + 2JZ-GE: 80's radness with 90's power/reliability/economy
    Quote Originally Posted by George View Post
    these wheels are so jap I even want to kill a whale. For strictly scientifical purpose, of course.
    Quote Originally Posted by rrfireblade954 View Post
    are you planning to drive it on the road?
    if so, are you planning to make it legal on the road?
    http://www.tmr.qld.gov.au/Safety/Veh...fications.aspx
    http://www.infrastructure.gov.au/roa...jan2011_v3.pdf
    if KE70 is listed as 970kg... you can get away with 3.88L NA, or 2.66L forced induction..
    so.. can actually get it legal (i thought it was just under)
    still, tough (and heavy) way to get 305Nm (eg for VY motor), whereas any turbo 2L will do that with maybe 8psi boost.. ie less than stock boost.
    but if it's cheap you want, by all means go or it
    edit: there was a KE20 somewhere with 3.8 Ecotec in it from memory..
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    2.66L eh id be going for a 1jz
    but thats just my opinion
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Oct 2009
    The rattletec makes decent torque and they are $200, its not the most refined motor but if your skidding it then its a pretty good choice.
    as if a 1JZ can be had cheaply and be modded chaeply for good power
    to be fair tho, 1J will be longer, but not sure about heavier?
    hell of a lot more potential, and factory have around 360+Nm vs 305 for ecotec.. then wind up boost with stock turbos...
    heck, you even have a JZ powered KE70 panel van to copy from...
    Oct 2009
    T5 + 3800 = $600~
    Whats a 1JZ and R154 worth, looking at $3000
  1. KE70 Engine Conversion
    By 2tnk4u in forum Tech and Conversions
    Last Post: 17-03-2011, 11:07 PM
  2. KE70 S13 suspension conversion
    Last Post: 15-03-2010, 12:25 PM
  3. Toyota Corona XT130 Holden 6 Cyl Conversion?
    By Trent-KE30 in forum Tech and Conversions
    Last Post: 07-07-2007, 08:49 PM
  4. Diff Conversion for KE70
    By Pnut in forum Tech and Conversions
    Last Post: 14-01-2007, 11:27 PM
