T series diff from a T-18 or a RA40,RA60 fit also i think, then get a LSD centre for them.![]()
I am currently doing up a KE70 and the diff (4.8:1) is somewhat noisey so it probably needs replacing. Is there a diff that goes straight in? If not what is a better upgrade. Ive heard that KE70 diffs are crap.
as mentioned the T series is ya best bet, unless ya wanna stronger one. lsd for a T series isnt cheep though.
Daily Driver: Holden Rodeo
Under Construction: RA28
Will The T18 or RA40/60 diff drum to drum bolt straight in or do I get the centres swapped?
RA40/60 will fit if you force them in. They are NOT a straight bolt in as the top mounts are out.Originally Posted by too_quick
Anything that fits an ae86 will suit your application.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
If you dont have enough money for a T series then a LSD centre Grab a welder and make a CIG locker, But be aware that this is illegal and takes time to get use to driveing a car with a locker.![]()
T18 diff is your best bet, it's the same chassis so it will bolt right in. Then you have access to all sorts of LSD's for the T series centre.
Norbie!
www.norbie.net
Lockers are sic,Originally Posted by too_quick
but yes they are illegal, and will cause your car to understeer especially in the wet. But a little throttle aplication will fix that.
Jordan
cvap has an lsd centre for a t series at the moment... yeah its $1100
http://www.cvap.com.au/?StartAt=8&Di...rch=Mechanical
ive got a t series open centre (ratio 4.1) that you can weld the sh*t if you like, you can kinda prug n pray whenever you wanna drag, ive also got some near new drums, hell i'll even thow in the handbrake cables, all for cheap too
craig
you have a 4.8:1 ke70 diff?Originally Posted by Pnut
im guessing thats not a stock item?
tell me more![]()
ya, where you find the 4.8 final gear set.Originally Posted by love ke70
mind to share ?
stock ke70 boar warner diffs are stong. it is only the planetary gears that are undersized, so get over sped and there fore break. the ring and pinnion and axles especially are very strong. much stronger than a t18 diff.
if youre on the cheap keep the borg and weld it. 4.3s are available for these also. welding cures the problem of the small planetary gears... they dont move anymore at all
t18 if you want something nice. infinate range of GOOD after market lsds. same can be said for ratios. well manitained set ups can even cope with 4a turbo power.
dont understand how people think T series lsds are expensive? maybe you cant get a true track ect.. but really they dont compare to the jap clutch style lsds. also when you buy them 2nd hand you usually get a nice ratio (4.3 or shorter).
Thank you all for your advice. CIG diff (welding) is not practical for a road or tarmac rally car. LSD would be great. Sorry for the typo on the ratio it is in fact 3.89. I checked the tag on the diff while doing a diff oil change yesterday. Using 50/50 ratio of Lucas 80/90 racing gear oil and Lucas oil stabiliser. Diff is now quieter but I suspect rear wheel bearings may be causing some of the noise. This I will look into further. Doing a full underbody check tomorrow night in preparation for next tarmac rally on 17 Feb.![]()
