Results 61 to 73 of 73
Thread: ca18det into a ta22
  1. #61
    Default Re: ca18det into a ta22
    Just so you know, corona diffs are just as weak as TA22 T series diffs. I have no doubts that you will be requiring a replacement before long, and being a borg warner diff, they are more difficult to change centres in (lashing is the biggest PITA).
    I strongly suggest you look for a better diff. Shortened F series or RN2x G series
    EDIT: just noticed it was locked too... the axles are not strong enough to take a locked diff, and it wont pass a roadworthy or engineering report with a locked centre. An LSD will fix this.
  2. #62
    sir Grease Monkey
    tasmania
    someone got it wrong the ca is belt and no rockers ,sr is timing chain and rockers .i look at them most days under the workbench. cheers bigwad
  3. #63
    Quote Originally Posted by big wad
    Bet you were wishing they were 3SGTEs and 3TGTEs
    Mind you, they probably wouldnt be hiding under a workbench...
  4. #64
    Who greased my Grease Monkey Baref00t's Avatar
    Apr 2007
    EDIT: just noticed it was locked too... the axles are not strong enough to take a locked diff, and it wont pass a roadworthy or engineering report with a locked centre. An LSD will fix this.[/QUOTE]
    Not taking the Diff, just the engine... Am looking at finding myself a Hilux diff, possibly LSD...
  5. #65
    Have a good search in the tech section for putting Supra LSD centres into Hilux diffs. There is a lot of info on it, and it isnt as straight forward as you may think. Still quite doable though. Also, the MA70 rear disks go on without huge amounts of dramas. Again, theres a few tricks to it, so its well worth looking at the current discussions.
  6. #66
    just in regards to the gearbox tunnel, i have a sr20 in my ke30 and there was no modding of the tunnel required to make the gearbox fit besides getting a gb xmember made up so i'm not sure if it will fit in a celica but if it can fit in my ke30 which i wouldn't think is much bigger then a celica, i'd say there wouldn't be much work to make it fit in a celica
  7. #67
    The celica T50 was an arseload bigger than the K40/K50 of the KE30 rolla. The tunnel is much bigger in the TA22.
  8. #68
    Apr 2007
    To save me hoisting the engine, 'placing' it, then measuring the gaps for engine mounts and waiting God knows how long for them to be fabricated, does anyone know the dimensions / have a template for the TA22/CA18DET conversion?
  9. #69
    Satan??
    PS,
  10. #70
    Apr 2007
    Cheers for that.
    Anyone else??
  11. #71
    Hoppers Crossing
    dude, best off to measure this yourself incase there is something different when u do the gig.
    u'd hate to be all ready to go only to find that the mounts didn't fit!
  12. #72
    Dubai
    nope i do actually know, i have measured one, the s13 box is alot bigger than all of the w5x boxes, shifter would have to be moved back about 100mm abd then ud have to move the handbrake back a bit, probably not worth it with the amount of work needed to be done.
    Yes the shifter sits back more but usually you can take the gear stick out and rotate it so it angles towards the dash. Other wise modify the original handbrake to work on a slight angle.
    My old ra23 didn't have an issue with fittin the s13 box. It was factory auto if that makes a different. The only thing was we needed to drop the sub-frame 100mm when changing the clutch.
    I don't think my mate's ke35 had any issues either.
  13. #73
    Hoppers Crossing
    celica_john ; mate any pics of that setup ; that would be great to see in both an RA and a KE...
  1. TA22 Facts and specifications
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-12-2021, 11:15 AM
  2. TA22 Brake upgrade/springs price help
    By Dangerous Dave in forum Tech and Conversions
    Last Post: 16-05-2006, 10:51 PM
  3. ma61 diff in a ta22?
    By weapon x in forum Tech and Conversions
    Last Post: 20-04-2006, 12:25 AM
