Results 16 to 21 of 21
Thread: 18R-GEU rattle at 4000RPM?
    Dec 2011
    Default Re: 18R-GEU rattle at 4000RPM?
    As Justen as said,
    Ive had several ALT tensioner brackets crack on these 18rgs and they make a horrible noise.
    Nov 2007
    When you say the tensioner bracket, you're referring to the curved slotted bracket attached above the water pump? Where would this normally crack? I've got a nasty noise at the front of my RG and so have parked it until I can get time to check it out but if its just an alternator bracket I'll fix it and start driving it again.
    Glen.
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Dec 2011
    Ive had them crack under the water pump bolt and at the start of the slot close to the pump.
    Welding is a temp fix, but they will crack again next to the weld.
    I dont have my 18rg anymore, but I did find the "C" channel shaped bracket was a lot stronger than the flat one.
    Just remove the tensioner bolt on the alt and you may find the bracket falls off in your hand.
    Nov 2009
    hmm sounds like you need a new diff
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Just check for a cracked bracket before pulling it to pieces. The right resonance will make it vibrate and they can make all sorts of noises. Had similar on my turbo 18rg once and had us scratching heads for a while as the crack was hairline and not easily spotted, but sounded like detonation at 3200rpm
    Hey Guys,
    I think we have this one solved. Because of the big ass stereo in the 30+ year old car , the alternator was replaced with a EA Falcon version as per another thread. The standard bolt has a longer thread and shorter shank than the Ford item. Where the alternator bracket met the thread has flattened and has just enough slack to vibrate. Removing this stopped the noise and the frustration
    Thanks for the suggestions!!
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Don't you love it when it's something simple
  1. 18R rattle
    By StuRT104 in forum Tech and Conversions
    Last Post: 06-10-2008, 08:01 PM
  2. won't rev above 4000rpm
    By hunging in forum Engine & Driveline Conversions
    Last Post: 25-11-2007, 09:41 AM
  3. Replies: 11
    Last Post: 13-07-2007, 11:45 AM
  4. HELP!!!! Running on 3cyl over 4000rpm
    By newbien in forum Tech and Conversions
    Last Post: 03-06-2006, 08:31 AM
  5. Replies: 34
    Last Post: 07-02-2006, 08:02 AM
