Results 1 to 6 of 6
Thread: Statically timing a 2t (ta22)
    Junior Member Backyard Mechanic Ashh's Avatar
    Nov 2012
    Default Statically timing a 2t (ta22)
    So I got a bit ahead of myself with adjusting my timing and now the car won't even idle.
    How do I statically time it so I can time it properly this time
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    Default Re: Statically timing a 2t (ta22)
    If you can get the engine running - even with idle set very high - you should be able to get the timing set to something close just by feel - ie, twist the dizzy a few degrees either way until you get the engine running reasonably smooth. Then use your timing light to get the timing set just right (10 degrees BTDC at around 800 RPM with vacuum advance disconnected). If you really want to try static timing - which is pretty fiddly - try this http://www.custompistols.com/cars/ar...ion_timing.htm
    Nov 2012
    Cheers ta22fan, it ended up being a disconnected sensor (the one on the side of the Carb. What does it do?). After that was reconnected she idled perfectly and timing her was a breeze.
    Jun 2007
    Will need a pic of the sensor to know what it is. At a guess i would say it was the idle fuel cut solenoid that was disconnected.
    Apr 2007
    As Dazza has said it sounds like the anti dieseling fuel solonoid, its designed to cut the fuel supply to the idle circuit when you turn the car off so you dont get any run on / pre ignition, its there for emmision puropses ..
    ( Iinitially reading this thread i thought there has to be something else than just the timing which it turns out there was )
    Nov 2012
    sorry about the late reply. You guys were spot on, it was the anti dieseling solenoid. As soon as I reconnected that it worked like a charm!
  1. Trouble removing 2T timing cover in TA22
    By ToyTA22 in forum Tech and Conversions
    Last Post: 19-06-2011, 07:20 PM
  2. Cam timing:
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 21-04-2011, 07:22 AM
  3. Timing chain rattle on a TA22
    By Genna in forum Tech and Conversions
    Last Post: 24-02-2011, 09:17 AM
  4. Replies: 25
    Last Post: 02-10-2007, 09:04 PM
  5. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 07:06 PM
