Transmission info is correct. Easiest way to check is to look for the kickdown cable coming off the throttle - the newer autos don't have it.
You could probably still use your older rebuilt auto but you would need to use an external controller for the older transmission - the factory ecu probably will not run it. (I say probably because there's a low possibility it will control enough, but you're on your own as I haven't heard of anyone trying it).
The engine in question is also missing the air con compressor and power steering pump - are these included in the price?
Mos.
