nothin' doin
Grease Monkey
20v vvti
is it necessary to run vvti with aftermarket ecu and a t28 turbo on a blacktop 20v?
the reason i ask is, my new engine has a broken vvti actuator.
would it be beneficial at all to blank off the hole in the side of the head, or maybe even set the actuator so the vvti is on all the time?
Originally Posted by
Rex_Kelway
i am of no speech
Re: 20v vvti
It should run with the VVTI off, as for setting it on or not, it's just like adjustable cam gears..
nothin' doin
Grease Monkey
Re: 20v vvti
yer, i know it'll run with it off. i spose i'm really asking if, with aftermarket management, would it be better to be set on or off?
Rex_Kelway
i am of no speech
Re: 20v vvti
Surely no amount of aftermarket management can make up for the more aggressive cam timing? I would leave it on.
nothin' doin
Grease Monkey
Re: 20v vvti
you don't reckon it'd run like shit when idling, or be sluggish in the lower rev range?
Rex_Kelway
i am of no speech
Re: 20v vvti
Continuously variable valve timing? There is also nothing to stop you running aggressive cams and VVTi apart from piston to valve clearance and intake - exhaust valve clash. Some clever work before you assemble the motor will allow you to ascertain the maximum amount of lift for a given amount of advance/retard at a certain point in the engine cycle.
With decent aftermarket control, you could use it to help with spool up and improve mid range torque. Drifter's paradise?
Re: 20v vvti
My silver top switched twice, it started at one position for idle and bottom end, then switched for midrange, then switched back again for top end (I think the switch points were around 1500 and 6500).
I dont like the term
Grease Monkey
Re: 20v vvti
you cant leave vvt on all the time! vvt advances inlet cam timing past 4500 rpm for better power cause you cant have the best of both worlds, get it fixed or leave it off, car manufactures do certain things for certain reason's, timing is supposed to advance more the higher the revs, you cant have the amount of advance the vvt give's at idle!
Grease Monkey
Re: 20v vvti
and because those engines need like 106 RON petrol all you'll do with to much advance is fuck your engine
PING PING PING
nothin' doin
Grease Monkey
Re: 20v vvti
what if i'm running Martini 110 in it all the time, being track only?
Rex_Kelway
i am of no speech
Grease Monkey
Re: 20v vvti
with 110 ron well?
i cant say for sure, personaly i wouldnt try it
chances are you still might run into detenation problems
cause you'll have about 30 deg adv at idle
Re: 20v vvti
Um - I'm not 100% on the blacktop, but, the silvertop only adjusts exhuast cam timing and doesn't touch ignition timing at all...
Grease Monkey
Re: 20v vvti
inlet cam timing, im sure its inlet cam timing
either way it will idle like turd, it would be like putting in a really lumpy cam
unless your using a fully programable aftermarket ECU you would not
be able to get desent idle
but if its a track car it wont idle often.
but i still think its risky business
Re: 20v vvti
As he has already said he is running a T28 turbo and aftermarket management, that really isn't a problem.
You're correct, the inlet cam moves, but, the distributor runs off the exhaust cam which is fixed. (I haven't owned one in years...)
For the timing figures, Bill Sherwood has them on his website here, you'll need to scroll down to the bottom.
nothin' doin
Grease Monkey
Re: 20v vvti
the VVT runs off the exhaust cam. the intake cam is fixed.
Rex_Kelway
i am of no speech
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
