Results 1 to 8 of 8
Thread: 2tg crankshaft issues
    Too old to be a Grease Monkey
    Aug 2008
    Default 2tg crankshaft issues
    Putting together an old 2tg as a practice build before attempting the real thing. Up to the bit where I tighten the bearing caps and try to get the crankshaft to turn as it says in my manual. When I tighten the bearing caps I cant spin the crankshaft at all. I have a torque wrench etc so all the bolts should be to the required spec. Not sure why the crankshaft is tough to turn? Any ideas from the master engine builders for a novice?
    Noof
    Feb 2012
    Wa
    Default Re: 2tg crankshaft issues
    Got the caps and shells around the right way?
    Aug 2008
    Yep, Only thing I can think of is I have two crankshafts and one could have been machined and require larger bearings. I could have the unmachined crank with bearings to suit the machined crank?
    That would cause me issues correct?
    Is there any easy way to tell? measure the bearings? Can someone tell me what standard thickness is?or whether I am completely barking up the wrong tree?
    It seems to explain my little issue though.
    Chiba
    Might be worth getting some plastigauge to check clearances between the two cranks.
    Tallahassee, FL USofA
    There will be numbers on the bearings & stamped on the crank if OS, .25 & .5 & .75 & 1.0 metric, .010 & .020 & .030 & .040 imperial.
    Does it happen with all 5 or 1 only?
    Don't bother with torque for now.
    Aug 2008
    Bearing cases have .25mm on them.
    Guess the crank could be original unground?
    Does anyone know the unground diameter of the 2tg crank?
    Junior Member Grease Monkey tojo's Avatar
    Aug 2009
    Norway
    andrewzuku has some mean scans on his site .- 2t repairmanuals . Link on the bottom of his posts
    https://toymods.org.au/forums/showth...t=767&page=781
    KE17 TE38 KE35 KP61 KZN130
    Aug 2008
    Thanks for the info,
    Will check it out when I get a chance
  1. Custom Crankshaft
    By Bazooka in forum Tech and Conversions
    Last Post: 17-12-2010, 07:42 PM
  2. W5x clutch pedal issues/Slave issues?
    Last Post: 11-05-2010, 06:27 PM
