Results 1 to 14 of 14
Thread: Custom Crankshaft
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Custom Crankshaft
    I'm looking to get a custom crankshaft made to destroke a 1UZ.
    Does anyone know and/or recommend a shop that could be able to perform this work?
    Thanks
    Junior Member Grease Monkey KENut's Avatar
    Jun 2009
    Default Re: Custom Crankshaft
    Offset grind?
    May 2006
    Nope as I'm going beyond what the standard crank can offer. Must be custom made.
    Hoppers Crossing
    you could try pro-stroke to see if they can help?
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    just out of curiosity what capacity are you after?
    Smile Re: Custom Crankshaft
    Hello crankshafts made to order SAINTY Terry the top fuel dragster guy
    May 2006
    It's common on chev's to use titanium caps to increase the bearing size once you go too far offset grinding. Been proven on many 1000hp + cars too, will save you $1000's of dollars over a billet crank. But I guess its how deep your pockets are.. If it's improved rod ratio your looking for a 2UZ block might be worth a look too.
    Penrith BC
    ../delete/ban
    tech moderator
    Penrith BC
    Quote Originally Posted by beerhead View Post
    from 82.5mm to 66.5mm offset grind on a 52mm journal? dont think so
    and whats with the 2UZ block. not sure that help RS ratio at all
    ed
    ../delete/ban
    tech moderator
    May 2006
    All I said is it might be worth a look, I'm sure you've got the experience on these things, but I've often thought about a 4AGE build in a 7AFE block, was hoping something similar would work the the UZ motors.
    So the 2UZ uses a shelf piston and the same length rod then? So you could run longer custom rods with the shelf pistons to get a better RR?
    Yeah thats a big offset, won't have enough meat I guess.
    May 2006
    Thanks all. As Ed stated I'm looking at a stroke of just 66.5mm which will bring the engine capacity down to 3.2L giving me a legal engine conversion in NSW.
    As this is going into a road car I'm not looking for an absolute top shelf item as I would be if building a race engine.
    Quote Originally Posted by Bazooka View Post
    You will be paying top shelf price for this work. Crankshaft Rebuilders here in Melbourne can also do this.
    Any reason you want a V8? Plenty of 3 litre V6s and with a little stroking/boring you could get them out to 3.2 litres. Would save a bit of coin too.
    price would be what? around 5-6K? more? less?]
    V6 would not sound as nice.... but smaller/lighter...
    Aug 2010
    Mackay, QLD
    Hey Ed, are they made by the same chinese manufacturer that is selling "1800hp" rods for different engines on ebay?
    http://cgi.ebay.com.au/4340-EN24-Bil...item5d2c2ed447
    Im a bit sceptical considering they quote 1800hp for nearly every engine.
    Their ebay store...
    http://shop.ebay.com.au/maxspeedingrods/m.html
    Anybody used their cranks or rods?
  1. Hypereutectic Pistons
    By Celica_73 in forum Tech and Conversions
    Last Post: 28-04-2008, 10:45 PM
  2. Toyota Crown MS63 Custom Wagon Info
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-09-2007, 01:31 PM
