Results 1 to 15 of 18
Thread: Gen 3 1GGTE dizzy wiring.
    Jan 2011
    Default Gen 3 1GGTE dizzy wiring.
    Trying to work out what's what with my distributor since I have 6 wires rather than the 4 marked out on all the 1ggte wiring charts.
    The wiring colours are
    red/white
    black
    black/orange
    red/blue
    black/yellow
    black.
    These are on the ECU side of the harness
    Dumbass gave some info that I'll follow up on in Scotts dizzy thread (thanks for lettign me get away with the hijack Scott!)
    But I'd appreciate any thoughts or experience other can bring to bear. This is effectively a follow on from my issues with not having sting spark to the front three cylinders, which I had thought o be a rotor issue. It's not. So now we are down to working through the ignition system and wiring.
    Nov 2011
    Default Re: Gen 3 1GGTE dizzy wiring.
    pull dizzy cap off
    the sensor with 24 teeth goes to pins ne- and ne on ecu
    not sure which wire is which as u need to try find diagram with wire colours
    then the 2 single pulse sensors are
    g1- and g1
    g2- and g2
    i could figure it out if i had the loom
    just make sure u get polarity right as inductive sensors work better wired one way than the other
    is this std ecu
    1ggs are pretty basic
    is it cut loom
    its it aftermarket ecu
    strnage y u get spark only to rear cylinders
    Jan 2011
    hey dumbass, I'll drop in and take a close look at it ASAP, but
    I'd thought it was a stock gen 3 with stock loom (although somewhat stripped down) and stock ECU.
    However, after looking through some posts by the previous owner, it looks like it started life as an AUTO, some of his posts are asking what he could leave off the auto ECU. However, my ECU is clearly marked M/T.
    Yeah, it was weird when we started the car up for the first time in almost a year. Front three plugs very weak spark, rear plugs very strong. First thoughts were that it was something to do with the rotor configuration of the 1ggte. Two rotor arms, each dealing with 3 cylinders (so it was a bit of a leap of logic). Couple of rotors later and problem remains.
    All the wiring diagrams I found/been pointed to on here and a couple of other forums, show only 4 wires. But we've had some colour mismatches on one or two other wires too.
    I think you've given us something solid to look at though.
    Nov 2011
    just look at all 1gg ecu pinouts
    see which ines have the ne- ne g1- g1 g2- g2
    if one has then seperate on ecu or the - all joined on ecu harness and nto in dizzy that might be right diagram
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Quote Originally Posted by masterofsinanju View Post
    red/white
    black
    black/orange
    red/blue
    black/yellow
    black.
    How manny wires are on the dizzy side of the harness, 6 or 4.?
    Nov 2011
    what version 1gg do u have
    as i cant find info with 6 dizzy wires going to ecu on my stuff at home
    pull lid of ecu and check for names on the terminals inside
    Jan 2011
    I'm fairly sure it is a gen 3 1ggte (not 1gg).
    I'll try to get a pic today, but it's six wires out of the dizzy. Will do with the ECU also.
    Nov 2011
    My gen3 dials have 4 wires for the dizzy
    In the end u can always put an oscilloscope on the wires
    There wires are easy to find which is for which sensor, u will have two wires per sensor
    So once u do that u have 50 50 chance to get it right
    MIT take abit of guessing but I recon I could figure it out in an hour
    So if everything else is ok then just guess hehehe
    I can't find any diagrams with 6 wires
    Jan 2011
    Dumbass. I took spook at the actual car this morning and point one is, miscommunication with my mechanic.
    Not talking about the dizzy. 6 wires are coming out of the coil/igniters.
    Wiring diagram does only show 4 wires.
    Loom was indeed auto and the auto related material was stripped out.
    Nothing else has been changed or mucked about with.
    We are now considering damage to the ecu as it shows some water damage.
    Nov 2007
    N.S.W
    just confirming the front 3 Cylinders don't have spark?
    sounds like the either G1 or G2 signal is missing, so faulty could still be with the ECU, dizzy or missing connection,
    Here is the test process it for 7M but same as 1G
    http://www.cygnusx1.net/Supra/Librar....aspx?S=IG&P=5
    http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=16
    or if you have spares swap out to test.
    Jan 2011
    Many thanks auto351. I'm looking for bits to swap out.
    I'm comfortable that the connections are ok and have already replaced the dizzy rotor.
    The ECU shows signs of water damage and it wont surprise me if something is cactus inside. So I'm on the hunt for one to swap in as a check.
    I'll try the test you've linked to. Thanks
    Nov 2007
    N.S.W
    where iare you located ?
    Jan 2011
    Queanbeyan.
    As you've probably guessed, this is all a bit of a learning experience for me, so I'm pretty much playing 20 questions.
    Nov 2007
    N.S.W
    you originally indicated Front three plugs very weak spark , is there now no spark to the front 3 plugs?
    have you checked for error code inside the ECU ?
    Jan 2011
    I'm not quite sure how to do that. I'm assuming laptop and connector of some description, but I'll trawl through some of the older threads on here to see what's what.
    Originally there was only weak spark to the front three plugs and that is unchanged.
  1. 1ggte dizzy help
    By boardmaniscool in forum Tech and Conversions
    Last Post: 21-08-2007, 10:22 AM
