Results 16 to 30 of 46
Thread: Help with electronic dizzy conversion for 18RG.
    Feb 2012
    Australia
    Default Re: Help with electronic dizzy conversion for 18RG.
    Hmmm... I'll make an electronic dizzy up with the 21R dizzy guts and test it out and report back here. I'll try this weekend. Thanks everyone =)
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
    Unbiased Grease Monkey Earlyrolla's Avatar
    The first hit on Google... Not 100% applicable to your case but very useful to learn about ignition systems.
    http://www.toymods.org.au/forums/tec...ion-guide.html
    There is plenty of info out there, in particular wiring diagrams if you search Google images.
    FYI - the pick up or variable reluctance sensor in the distributor is nothing more than a coil of wire wrapped around a ferrous (metal) core. If someone says it is 'open circuit' they mean the wire has burnt out or broken so when you measure across the two wires with an Ohm meter (or a multi-meter set to resistance measurement) you will see no connection between the two wires.
    Feb 2012
    Australia
    Ahh okay, Would that normally impede the car starting? Because I drive it daily with the 4K set up but it still runs a resister and a coil O___o It confused me...
    Also I have already read that, It was one of the very informative threads that helped me out getting this far =P
    Feb 2012
    Australia
    Hey everyone, I'm doing the conversion to an 18R dizzy now and I'm curious where the 5mm fish tank hose goes? O___o
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    is that the vaccum advance hose
    if so it goes onto the carby vaccum line
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Feb 2012
    Australia
    No, I heard the you need to put a piece of 5mm fish tank hose on something inside the dissy or you get to much advance? O___o I can't find info on it...
    Feb 2012
    Australia
    Don't worry, If I didn't know the difference from vacuum line to fish tank hose, I probably shouldn't be working on cars all the time XD
    Feb 2012
    Australia
    Bump, Need help with this, Or atleast a link on some info please.
    http://www.toymods.org.au/forums/tec...or-dizzys.html
    Some info in here which may be useful?
    Feb 2012
    Australia
    Thank you, I think I worked it out though, I'm getting some fish tank hose tomorrow then I'll put up some pictures in case anyone has the same trouble as me... Then I can finish the damn thing! =P
    Apr 2011
    vic
    I'm guessing when your talking about fish tank hose , its slipped over the pins increasing the dia slightly to limit the travel of the advance arms. You can also add weld to the arm and grind it to suit , the fish tank hose is a quick fix but will slowly wear and alter your advance limit.
    Feb 2012
    Australia
    Yes exactly! And I thought it'd go brittle quickly, Fish tank hose isn't exactly heat proof >___> I'll use the stuff just to get it working then maybe I'll alter it to something permanent later on.
    Feb 2012
    Australia
    Turns out the dizzy I did the conversion to was a 16R dizzy =P No cutting required!
    Anywho, What are the pro's and con's of a Non-adjustable duel vacuum diaphragm versus a an Adjustable single vacuum for the electronic dizzy.
    Also if I use the single vacuum, Do I have the vacuum line run from the carburetor or the intake manifold? The 18RG currently has a dual vac, hence the two vacuum output options there =P
    Feb 2012
    Australia
    Bump... Sorry for that but once I know which is better I can finish the dizzy and get to the wiring!
    Apr 2011
    vic
    Just go with the single to the carb, quick simple.
  1. 2TG Electronic Dizzy
    By Grega in forum Tech and Conversions
    Last Post: 26-07-2006, 08:41 AM
