Looks like a fun Job !! i think i will stick to the 1 + 2 jz ..
Best way to get the spark plugs out once undone is just get a straight spark plug lead off a an old Falcon or the like & push it down over the loose plug & pull out via the plug lead the rubber boot on the lead will hold the plug in & you can also use it for refitting & you can even initially screw the plug in as well ..
Those coil packs from memory look very similar to the 1jzgte vvti coil packs ...
