I'd start with checking your points - I've seen problems a bit like this caused by a bit of oil/dirt partially shorting the points gap. Also, give it a try this arvo - could be old high tension leads which can absorb moisture overnight causing higher than normal resistance - when this happens they often come good after a few hours in the warm/dry. Sounds like you've got 12V from the "Start" circuit to the coil (lead runs from the solenoid direct to coil +ve terminal) - check the normal running 12V circuit that runs to the ballast resistor on top of the coil, and then to the +ve coil terminal. You should have roughly 9V across the coil terminals from this circuit with the ignition in the ON position (points closed). If all that checks out, I'd swap the coil out as a next step.
