Results 1 to 4 of 4
Thread: 4A-GE starting problem - weird one...
    Time to spank the Grease Monkey
    Default 4A-GE starting problem - weird one...
    Okay, if I put the key in the ignition, turn it to ON, the fuel pump, thermo fan and A/C fan come on (which they shouldn't).
    If I turn to START, the starter motor does not go on, and the pump and fans remain on.
    If I turn it back to ACC, or LOCK and take the key out, the pump and fans remain on until I disconnect the battery. If I disconnect the battery with the key still on ON, the pump & fans come back on when the battery is reconnected. If I do this when the key is on LOCK or ACC, they remain off when reconnected.
    It did all this last week, I couldn't start it, but the next day it did. Started fine for a two days, then started doing it again.
    I have checked fuses, some relays, I've checked the ECU fault codes, nothing seems out of the ordinary... apart from everything it is doing!
    Any ideas would be extremely appreciated!
    AE92 Lueno GT-Apex (zenki Trueno with a Levin front end) - BT 20V & LSD
    KE30 Tudor - 2T-GEU, T50, T292
    My Missus is a Domestic Engineer BradW's Avatar
    Default Re: 4A-GE starting problem - weird one...
    Make sure the battery terminals are clean and tight. Check that the main earth connections on the chassis and block are also clean and tight.
    You could also check the main ignition relay but I don't think this would cause it to not crank.
    Hope this helps.
    Brad
    Old Corollas never die...
    My KE30
    ignition barrel..??
    Got a Sparky onto it -
    Not starting: Due to loose earth lead from engine to chassis, coupled with -
    Fans & fuel pump staying on: Terminal that a relay was on was loose and getting power, keeping the fans etc on.
    Took him 15 minutes - Grrrrrrrrrr!
  1. 4AGE Starting Problem
    By druu in forum Tech and Conversions
    Last Post: 18-09-2006, 09:23 PM
  2. 1UZ-FE starting problem for the electrical Guru's
    By "Z" UTE in forum Tech and Conversions
    Last Post: 14-06-2006, 11:46 AM
  3. Weird firing problem
    By whatthe? in forum Tech and Conversions
    Last Post: 21-05-2006, 10:47 AM
  4. MZ20 Soarer starting problem
    Last Post: 05-03-2006, 06:19 PM
