The main constituent of acrylic thinner (2 pak included) is toluene... one of the best octane boosters on earth. So yeah... shes flamable alright. Makes good octane booster cheap tho, a 20 ltr drum is good for about $40ish, and its rated somewhere close to 114 octane, or some other super high number.Originally Posted by LeeRoy
If indeed it is an RT142, they infact have glue in screens. My suggestion is get a glassy in to remove if its necessary, otherwise leave it there. Remove windows and cover with cardboard (the open space in the cabin will a) get paint stuck on stuff you dont want it to be stuck on, and b) cause turbulating air which will cover your car in paint dust and make buffing a royal pain in the a-hole)
Also, dont wet sand bog, its porous. Use a bog file, then paint with spray filler, and allow to dry.
Primer stretches and flexes while drying. Allow primer to dry for about 2 weeks before giving a very light sand, and painting with colour. Spraying cheap acrylic matt black in super thin dust coats over the primer between sanding will show up high and low spots really well. Got a badly rippled/rust repaired XA coupe body straight as a die using that method.
You can buy hand sanders which are somewhere near 2 foot long and about 2 inches wide. These are the best things since sliced bread, and you can buy the sheets to fit them. Dont buy cheap stuff... a good hand sander like that will set you back over $30, maybe over $40.
