So due to my circumstances webbers/carbs are out of the question. dose any one have any other suggestions on what could be causing the my problem.
thanks
Yes, $600 would get me a pair of 40mm side draught mikuni replacement webbers. $1000 plus would get an ECU... And i was talking about a replacement ECU, not the existing one, as stated.Originally Posted by Norbie
thanks
Can you run the fault code test?? not sure the exact procedure on this, but pretty much every ecu has this fault code test, by shorting a pair of wires, and adding a light to another pair. This should be done after the car has run, and if there is anything wrong, then you will get a series of short/long flashes. From there you look up the table of fault codes, and it tells you what sensors are mucking around.
				thanks. ill look it up when i get it runing
2T-GEU EFI is the old analog L-Jet setup. It doesn't have anything as sophisticated as self-diagnostics I'm afraid. What do you expect from late 70's electronics?Originally Posted by o_man_ra23
Norbie!
www.norbie.net
i have a 32bar map in a word document, if u end up getting a haltech or sumthin let me know and il give u my map as it worked pretty good on my enigne, ran a lil bit rich but it still killed toranas.
good luck
				thanks, if i do that would be great
				ok ill give it a miss if it ant thereOriginally Posted by Norbie
thanks any way
