was the chirp noise in the video?
G'day all,
This problem is driving me insane!!
My drive belt chirps and i've tried the following:
- New belt
- New tensioner bearing
- Different tensioner (used off another motor)
- New AC pulley bearing
History is that I replaced the motor and have bolted on all accessories on to this one and haven't gotten it to run quietly since. Now i'm pretty sure the problem is pulley alignment. I have used a straight edge and found the powersteering and A.C. pulley are slightly off. The only thing is that no matter what I try I can't get them to line up properly. The A.C compressor allows a bit of adjustment but the powersteering always seems a tiny bit off. Any tips to adjust this properly??
Here's a video I took just after adjusting it a bit and putting on the belt. It's quite hard to hear but it gets louder after a bit of a drive then quietens down sometimes after a long run. It might be my imagination but you can also see the belt moving around a tiny bit on the power steering pulley. With the belt off none of the pulleys move.
http://smg.photobucket.com/albums/v4...26_095255Z.mp4
Heres a couple pictures that may/may not help:
http://img.photobucket.com/albums/v4.../WP_000443.jpg
http://img.photobucket.com/albums/v4.../WP_000442.jpg
http://img.photobucket.com/albums/v4.../WP_000441.jpg
http://img.photobucket.com/albums/v4.../WP_000440.jpg
Any help would be MUCH appreciated.
Hash.
1977 RA23 Celica -> 1ggte conversion [SOLD]
MA70 Supra 1JZ 5speed [SOLD]
Current: IS200 1JZ VVTI 6 speed
How are the groves on your pulleys? Possible one is fucked?
Use a piece of hose to determine where the chirp comes from exactly.
The only reason for a pulley to be off the line is physical damage, in this case you would probably need shimming/welding/cutting etc. But it's more likely that one bearing is a bit fkd up as said above.
yeah id be more inclined to say a bearing is on the way out
As is said above... if memory serves correct a chirping serpentine belt can be caused by the tensioner spring becoming weak or even "the beginning of the end" of the harmonic balancer so I would look there
His. 2005 GRJ120 Prado VX
