Results 1 to 8 of 8
Thread: 1JZ main drive belt info
    KE25 legendary Backyard Mechanic Robbo's Avatar
    Jun 2006
    Default 1JZ main drive belt info
    Hi all,
    building myself a GZ20 track car...being a track car i'll have no aircon and i am trying to remove as much weight as possible..and retaing some interior
    i need the belt length for 1JZ without a/c compressor anyone know it?
    any help muchly appreciated,thankyou
    Rob
    !!! BAN LOW PERFORMANCE DRIVERS NOT HIGH PERFORMANCE CARS !!!
    私のトヨタはある従って速い均一死んだ人叫ぶ!
    Western Aus
    Default Re: 1JZ main drive belt info
    PM Adsport or CoFFee, cant remember the exact size, otherwise id tell ya, but i was with coffee when he bought his.
    Elmo.
    Jun 2006
    i'll ask adam
    Graphic Designer Grease Monkey Petes77celica's Avatar
    Or you could just wrap a piece of string around it to get the correct length thats what i have to do as ive changed water pump removed power steering and A/C.
    Pete
    1977 RA23 LT CELICA
    Here it is right here http://www.toymods.net/forums/showthread.php?t=23121
    sir Grease Monkey
    tasmania
    i deleted my ac pump but fitted a hilux steer pump and had to modify the throw on the belt tensioner. then pulled the tensioner down hard and held with a wire tie .then just run a tape measure round the pulleys. you can get a 6 rib belt in any length you want from your local parts supplier .i went with the tape length 1335 mm and should have gone 1340. it cost about $25. cheers bigwad
    Toyota Farmer Grease Monkey Yotaholic's Avatar
    Feb 2007
    NFLD.
    The belt I used when I took out mine was Dayco # 5060735 .. Tensioner has plenty of room for stretching and it fits perfect. Hope it helps
    82 Ma61 1JZ/R154 HKS Twins
    94 JZA80 V160 S475R (sold)
    94 JZA80 V160 T51R KAI CDN. Spec
    I think it was a 6PK1860 or 16PK1880 that I used on my 1JZ with deleted AC, something in that range. Have a search as I put the exact belt up in another thread.
    244rwkw / 328hp @ 18psi
    Jun 2006
    cheers for your help guys
  1. 1JZ ECU capacitor replacement info
    By Ribfeast in forum Tech and Conversions
    Last Post: 17-05-2017, 09:37 PM
  2. 1JZ Timing Belt Installation
    By ReQuieM in forum Tech and Conversions
    Last Post: 18-09-2006, 11:19 AM
  3. 1jz vs 2jz heads
