You line the chain up via the TDC of the pistons(check with a screwdriver down the plug hole, not the mark on your crank pulley). From there you set the camshafts so that the grooves on the top are at the top, line them up with the arrows on your No 1 cam caps. Ive never seen aftermarket chains with the shiny links, so that idea will go out the window anyway and you will have to line them up as i have described. Im not sure if OEM chains have the breaker links, but they can be removed with bolt cutters etc. It isnt really that difficult, just time consuming and frustrating.
Only one worth it really
