Results 16 to 25 of 25
Thread: AW11 (mk 1 MR2) cold air intake
    Jul 2009
    Default Re: AW11 (mk 1 MR2) cold air intake
    Quote Originally Posted by Xenon676 View Post
    Oh yeah that little diameter tube you have connecting that scoop and the filter isn't restrictive in the least LOL Let alone you talking about traveling 3 foot thru a hot engine bay. TRY again.
    LMFAO, if 3" tubing is restrictive on an 1.6L NA motor making 90KW, I guess every car in the world should have 10" intake tubing.
    Get your head out of your ass
    Jul 2007
    TO be fair to knightrous, if the fitting is no smaller than the intake manifold entry, it isn't a restriction (although it can be for other reasons). Also, plastic is a good heat insulator and that length of piping travelling through the engine bay is actually pretty damn short, the difference to the factory length going to the boot would be negligible.
    But anyways, maybe this will make you happier
    Oct 2009
    I just ran a pod 50mm above the LHS stub axle, intake temps were fine.
    Junior Member Conversion King
    May 2010
    I've never seen any bigger than 3" tube on any turbo car, including 500HP Evo's and STi's. Hell I even vividly remember a 1000HP skyline that only had 3", although it was a twin turbo.
    Also not knowing enough on the subject, I thought bigger diameter tube's can also cause air characteristics to negate any effect of vortices or anything beneficial to when for say, you are feeding air into a compressor wheel or through an intake manifold.
    I thought the idea is you want to create pressure differentials at strategic points in order to aid vacuum or boost, so no universal length or width of pipe is going to be perfect in all situations.
    Pod filters in particular suck air from different angles to assist this, not just because they have a larger surface area.
    May 2014
    Nebraska
    LMAO he thinks of the diameter of the tube and then doesn't see anything else about it. The tubing he is using is cheap ribbed flex tubing. Now this wouldn't be a issue if it wasn't expanded or bent in any form or fashion. When air hits a object the air flow changes according to the angle of the object and force ( speed ) of the air, Determines the amount of direction change. When air hits these ribs multiple times it can and probably does create a vortex around it self. For even when air comes into contact with it self it still provides a resistance to air flow direction. This is the basis for finding your scoop and cheap tubing more entertaining then effective. But then if you want to start trading insults I can do that with you to jagoff.
    May 2010
    And come back to his original argument, does a ribbed tube really matter on a 16v NA 90kW engine?
    Constructive criticism is always welcomed, where as insults are not.
    Carbon neutral Carport Converter Jt_70R's Avatar
    Putting thinner oil in would probably see a more noticable power gain then a non ribbed-for-her-pleasure-tube
    Jul 2009
    Ribbed piping or not, it's not a restriction to this motor and it's certainly a much more effective setup then an exposed pod filter in the engine bay or open air ITB's.
    Jul 2007
    you gotta extract every 0.1kw you can man!!!
    Oct 2009
    lol who is this guy?
    Take a big shit before you drive if the ribs matter that much
  1. [reasonably] cold air intake for n/a?
    By George in forum Tech and Conversions
    Last Post: 25-06-2012, 03:38 PM
  2. Cold Air or Ram Air Intake - will this improve power?
    By JAIFRESH in forum Tech and Conversions
    Last Post: 15-01-2007, 08:56 AM
  3. cold air intake
    By 5-0 daner in forum Tech and Conversions
    Last Post: 19-05-2006, 12:41 AM
