Results 1 to 10 of 10
Thread: cold air intake
    Default cold air intake
    Hey how are yaz,
    ive got a 4agze in an ae82 corolla hatch n i was jus wondering as to wether
    anyone has designed a cold air intake for the same situation? any help would be greatly appreciated!!!! cheers
    Default Re: cold air intake
    if uve got an intercooler, then u shudnt have to worry to much about a cold air intake. otherwise, u could box off ur pod filter and run sum pvc pipe from under the box to behind the front bar...
    easiest way to get it done i reacon...
    JZA023
    ive got a top-mount intercooler which is fine but the problem is that when the battery goes in the intake pipe comes down straight into where the battery sits and the airbox has to be legal so i can get it engineered
    Battery in the boot for more room then run the filet closer to the front, box it in so its legal, then cut a hold in the bottom of the battery tray and run a tube down. There is a good post about relocating a battery that will help you out if you travel this route
    - LeeRoy
    Why not? Every bit of cooling of the air is going to help!
    ^^ thats 100%. but its an ae82 wif a 4agze. that extra 3kw isnt gonna really effect it a whole lot. ahahahah
    how hard is it to engineer a relocated battery...? any troubles wif it at all???
    JZA023
    Its pretty easy and engineers won't have any probs as long as its done right. It needs to be enclosed in a battery box which you can buy at supercheap auto, and the box needs to be mounted solidly and the battery also needs to be mounted solidly. I'm not too sure but i think the boot also needs to be ventilated. But most boots are ventilated anyways.
    - LeeRoy
    Battery in boot, then get a SX rolla or GZE map airbox setup and mount it in the same place. then you can make the cold air entry into the airbox bigger and the inner guard hole bigger and you will get alot more free flowing cold air and be legal.
    relocating the battery is very tempting bcoz i wanna have a dual battery setup later on n that would make it a lot easier. does n e one have n e pics of the situation described above? any pics would b great
    Have a look in members rides for an engine bay shot of a corolla. You will notice from front to back it goes:
    - Pass side headlight
    - Battery
    - Airbox
    And all 3 items are hard against the inner guard so check pics for full understanding
    - LeeRoy
  1. N/A intake resonance tuning
    By tricky in forum Tech and Conversions
    Last Post: 09-05-2006, 03:16 PM
  2. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  3. Wobbly steering under braking when cold
    By Ta2272 in forum Tech and Conversions
    Last Post: 07-02-2006, 10:59 PM
  4. Underbonet & Intake temps
    By Alchemist in forum Tech and Conversions
    Last Post: 09-12-2005, 03:56 PM
