Results 16 to 17 of 17
Thread: 22R TDC - Timing marks don't line up?
    SPANNER CRAB Grease Monkey AE3SGTE's Avatar
    Jul 2007
    Default Re: 22R TDC - Timing marks don't line up?
    Go it all together, new radiator in, and the water pump shit itself...always happens in 3's.
    Last minute dash to Repco at 3:30pm and now she's all sorted.
    Its pretty easy to pull the cover, just follow those guides and make sure you note which bolt comes from where and don't miss the hidden bolt under the dizzy drive in the pool of oil.
    Word to the wise, paint stripper works a treat as gasket remover!
    Yeah, the corners where the timing case meets the head and the block, I put a big whack of permatex red high temp in there.
    Not a drama with leaks, did the same with the front and corners of the sump -seems all good, but time will tell.
    That manual is really good for torque settings - esp dizzy drive bolt and crank bolt
    Sep 2011
    Quote Originally Posted by AE3SGTE View Post
    Indeed, I was searching for quite a while to get the torque settings.
  1. 1uz timing belt change marks always out
    By Z2TT in forum Tech and Conversions
    Last Post: 27-11-2011, 11:51 AM
  2. 20V Timing Marks
    By Just1n_mc in forum Tech and Conversions
    Last Post: 06-10-2010, 06:30 PM
  3. timing marks on 18R-C
    By StuRT104 in forum Tech and Conversions
    Last Post: 20-10-2008, 09:16 PM
  4. timing marks on toyota 12R motor?
    By vanman in forum Tech and Conversions
    Last Post: 16-08-2006, 01:22 PM
  5. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 11:00 AM
