Page 8 of 32 FirstFirst ... 67891018 ... LastLast
Results 106 to 120 of 470
Thread: 4A to W Series bellhousing
  1. #106
    Default Re: 4A to W Series bellhousing
    Pffft, sleep is for the weak!
    Sorry I havn't got back to you mate, I'm still waiting to hear from Brendan at Niteparts, once I do I'll let you know.
  2. #107
    what do you guys think of something like this?
    it adapts the w5x box to 4a bellhousing. you then run your 4a flywheel and p/plate and get a clutch plate that has the w5x spline.
  3. #108
    Extreme Procrastinator Grease Monkey PuGZoR's Avatar
    So it goes from the W5x to the stock T50 bellhousing, which in turn fits straight on the 4A?
  4. #109
    Anymore word on these bigworm?
  5. #110
    Quote Originally Posted by PuGZoR
    yep, some dude in tassie knocks them out i belive. have you guys considered this option as oposed to a full custom bell housing?
  6. #111
    The adapter looks the goods, but I think you would be limiting your options of flywheel/clutch setups. ie. single plate/small diameter. Ok for an N/A motor though.
    cheers Chuck.
    MS51Crown Coupe,
  7. #112
    fair call, according to one guy who put one in, the shifter comes up perfectly in the right spot in the sprinter (w5* with center position shifter).
  8. #113
    Yeah, I'd be worried about it fitting the larger GZE flywheel or anything else people are using... that'd be my main concern. (I'm using a GZE Fly)
    Also, I guess, if a copper had a look under ur car, even a quick one, that'd probably stick out like ducks nuts.
    Edit: Regardless, looks like a top quality item if it is a real option for someone who can use one.
  9. #114
    Jun 2006
    Tasmania
    Why would there be a problem with clutch flywheel choice??
    Where can i get hold of the guy making these as im from tassie, might be a cheaper option that the bellhousing.
  10. #115
    Only reason it might be a problem is because there are different sizes for some of the 4A engines. Eg, sure the 4AGE came with a T50, but the 4AGZE's never did, and they have a larger flywheel, so this may not fit inside the T50 bellhousing that this adaptor mates to.
  11. #116
    The GZE flywheel is the only one which wouldnt fit, all the rest would be fine.
  12. #117
    vic
    Quote Originally Posted by cri_ag
    Yep, definitely keen if its priced right, but would like to hear from someone who has fitted and used one first to comment on quality and any issues?
  13. #118
    Also interested in that option too. But just considering the influences of having the 20mm ish depth reduction in the input shaft. I would assume that this may interfere with the amount of meat which the clutch plate comes in contact with, and i also assume that the spigot bearing needs to be spaced out...
  14. #119
    Quote Originally Posted by BigWorm
    Don't suppose you've heard from the big man, BigWorm?
  15. #120
    Takai, yeah the input shaft /clutch plate centre engagement could be an issue, but hey the guy does supply the spigot bearing cure (middle of pic) The other problem, possibly, is the throwout bearing being pushed 20mm futher foward on the input shaft sleeve.
    cheeers Chuck
    MS51Crown Coupe,
  1. Imports101 MaxAction Second Series 2006
    By GeneSPIDA in forum Western Australian Events
    Last Post: 10-12-2006, 07:17 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
