Results 16 to 19 of 19
Thread: 1JZ to 2JZ GTE water pump woes
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Default Re: 1JZ to 2JZ GTE water pump woes
    Yep, found a copy on line...(I was right with the 210kg/cm bit - and not that far off the conversions..)
    GOOGLE! why hast thou forsaken me!
    now i can't even get it to try converting it..
    How'd you go with this? I'm not far of doing my pump as well...
    Malicious
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    We done it not so bad...
    We are so happy now we can easily access the turbos as I think I need to replace both of them again...
    Problem with the 2JZGTE water pump is the hard line that goes into the back of the pump, the studs for that are a bit short... My brother installed the water pump yesterday and just tightened them up as much as he could and left it as we couldn't be bothered changing the studs for longer ones. So we used gasket glue (slastic) to the bolts.
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
  1. 4S-FE Water pump equivalent
    By deeps in forum Tech and Conversions
    Last Post: 04-12-2006, 05:34 PM
  2. 1jz to 2jz
  3. 1jz vs 2jz heads
