Grease Monkey
1jzgte performence manifold HELP
Hi everyone
i was just hoping on a bit of help.
Im having a bit of a problem with my new intake manifold . i currently have a 1jzgte in my mkiv auto supra and i
came across a performence manifold and decided to have it.
i have taken off the inlet manifold but there seems to be lots of pipes plus water pipes going into the inlet manifold.
and on the new manifold it looks as if thiers no where for them to go. plus what would i do with the kick down cable(load sensor).
kind regards lee
Re: 1jzgte performence manifold HELP
you can bypass all the waterlines that used to run through the idle control motor and the throttle body... just run a hose from the front of the block to the back of the block to bypass it...
as for the kickdown cable you will need to modify the new throttle body so it allows it to work in the same way as the old one or you can say goodbye to your gearbox...
Grease Monkey
Grease Monkey
Thanks for the info buddy. I'm thinking it would be easier to go single turbo aswell as that would get rid of most of the vacc piping am I right on thinking that? Plus on the back inlet holes there caped with oil I think due to the seals gone in one of the turbos.
Thanks lee
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
