Results 1 to 13 of 13
Thread: Are 4agze flywheel bolts single use?
    Toymods Club Member Grease Monkey
    Default Are 4agze flywheel bolts single use?
    Also after torque settings for fly and pressure plate.
    Thanks.
    Victoria, Mt Macedon
    Default Re: Are 4agze flywheel bolts single use?
    Technically I think flywheel bolts are single use. However I ordered new ones when I first installed my engine and have re-used them 2-3 times since without issue. I know their history and they haven't been abused.
    Pressure plate torque I do by feel.
    Flywheel torque: https://www.google.com/search?q=4agz...el+bolt+torque
    Cool thanks.
    Genuine bolts are only $4ea so I'll change them while I'm at it.
    Chiba
    ARP bolts are pretty cheap too. I used a set when I did the clutch in my Levin. Cheap insurance.
    Jul 2009
    Quote Originally Posted by GZE016 View Post
    Cool thanks.
    For the $4/bolt, it could save you $250+ when this happens...
    Oct 2009
    You can re-use them but for the love of god use a good torque wrench, ensure the mating surface of the flywheel is clean and do them up in the correct sequence.
    Flat chat with a $20 rattle gun will result in a fucked crank and fucked gearbox.
    Quote Originally Posted by knightrous View Post
    well up until now I have been "whatever", you sir have single-handedly converted my mindset. Did that happen to you?
    Jul 2007
    again - yes they are reusable but for the $25ish that a set of ARP bolts cost you would be stupid not to replace them. I have seen first hand the absolute mess caused by some flywheel bolts backing out and it just aint cool...
    Oct 2009
    Meh, I'll be buying new bolts when I change my clutch. Too cheap to not to really.
    loctite is also your friend
    Oct 2009
    Not really a fan of using it where its not specified to be honest but plenty of people like to use it
    Jul 2009
    Quote Originally Posted by Sam_Q View Post
    Indeed it did. It mashed the crank surface and the flywheel surface enough that it would require 2mm to be machined off of each to make useable. Ended up costing me around $250+ after I bought a new crank, flywheel, crank bolts, sealants and paid for the tow truck to bring it home. I'm still of the though that flywheel bolts can be re-used and I'm not going to preach to people that they are not, but after this little venture, I'm just going to buy new bolts in future.
    I'm just glad it let go at 40km/h on a quiet road and not at 110km/h (8500rpm) which the car was doing the evening before...
    Genuine Hotty. Conversion King old_mr2's Avatar
    I reused mine when I did my rebuild. Used an Ebay torque wrench and loctite.
  1. 2TG Flywheel Bolts
    By dougTA22 in forum Tech and Conversions
    Last Post: 27-07-2011, 06:37 PM
  2. Jz- 4ag arp flywheel bolts
    By YGO 08 in forum Tech and Conversions
    Last Post: 14-06-2011, 09:25 AM
  3. 1JZ Flywheel bolts
    By Pimpin_1JZ in forum Tech and Conversions
    Last Post: 11-03-2008, 04:50 PM
