Results 1 to 5 of 5
Thread: Silvertop Crank Pulley Vs Smallport Pulley
    Junior Member Grease Monkey rick q's Avatar
    Default Silvertop Crank Pulley Vs Smallport Pulley
    The crankshaft mounted fan belt pulley on my Silvertop has come loose, hammering the keyway in the pulley.
    From ToyoDiy.com, the part number is 13470-16030 but I can't find a replacement readily. The Part No for the smallport pulley is 13470-16010 - so it must be different.
    Can anyone tell me what the differences are? Could I use a smallport pulley and machine it or space it to make it work on my Silvertop?
    FWIW, the cam belt pulley [also destroyed] is the same part number as the Smallport, and so is available locally from Toyota.
    Thanks in advance
    Cheers ..... Rick Jones
    Fraser Clubman
    Default Re: Silvertop Crank Pulley Vs Smallport Pulley
    I have fitted a bigport to a blacktop, I had to take 3mm off the back of it and then it fit nice.
    Thanks Sam.
    I found a Smallport one and measured it against by dead Silvertop one and couldn't find any differences [apart from the part number!]
    Front pulley now machined off and the clubbie is back on the road!
    Fraser Clubman
    Mar 2011
    Part number can vary due to different suppliers of the part to Toyota during production.
    SHEPPO..
    Jul 2008
    Auckland
    20v ST and 16v smallport/big port FWD pulleys are the same.
    20v BT has a better harmonic damper and the snout is also 2mm shorter as the crank sprocket is 2mm thicker to accommodate the thicker cam belt.
    Now 9AGTE 410kw atw
  1. gze sc12 176mm crank pulley & 103mm s/c pulley probs
    By stepan117 in forum Tech and Conversions
    Last Post: 28-02-2010, 10:35 PM
  2. Silvertop cam pulley.
    By M.J.H in forum Tech and Conversions
    Last Post: 28-11-2008, 04:32 PM
  3. Replies: 36
    Last Post: 23-04-2007, 03:28 PM
