Results 46 to 56 of 56
Thread: Priming Oil Pump following rebuild
  1. #46
    Default Re: Priming Oil Pump following rebuild
    looking at them online i can see how you could mess it up...... but yeah still.....
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  2. #47
    (assuming a composite gasket)
    surely compressing it, and spraying it with hylomar (which should have been done) there will be bits and pieces of gasket and hylomar all over both surfaces. i dont mean machine them again, but scrape all the shit off, prepsol it and make it all 100% assembly clean again.
    recently i tested my new head on the existing engine then pulled it off less than a month later, i still had to spend an hour prepping the head again before it went on the new short block.
    working clean and general surface prep is the #1 thing when putting this stuff together (hence always having the air going)..... i spend more time cleaning than on tools when i build an engine, bhg job etc.
    Never late in an x8
  3. #48
    Quote Originally Posted by roadkill View Post
    i think you'd be safe to not have to do much to either surface as the gasket was never heated and engine ran so it won't have done it's job. Obviously though have a good look over both faces to make sure there is nothing still stuck on.
    BTW - how the smeg did you put the HG on the wrong way?
    bEn
    Cause i'm a tard??? LOL
    The really bad part, i distinctly remember flipping it over because i 'put it on the wrong way' the first time....woops
    27.90s @ Esses Hillclimb
  4. #49
    Aug 2011
    and that's how we all learn some thing new
  5. #50
    Apr 2007
    Wheres the oil pressure switch take off on these motors ?? .. Did you ever run it crank / it with the oil filter off & if so did any oil come out ...
  6. #51
    i googled what a 3s head gastket looks like. Could be fairly easy to do compared to others......
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  7. #52
    Quote Originally Posted by lexsmaz View Post
    Off the cylinder head.
    I did crank it with the turbo oil feed off, and yes oil did come out.
  8. #53
    Jul 2007
    just be thankful it wasnt anything more serious
  9. #54
    This thread needs a face-palm pic :-)
    Glad you found the problem.
    I've taken note of the things I should've done when assembling my engine, but didn't. Like turning it over to build oil pressure without firing it up. But I did use a 2nd hand pre-assembled bottom end, not new bits.
    And I'm really glad that mine worked straight away despite the mixing of the Gen 3 & Gen 4 bits.
  10. #55
    THat's awesome news Roundy, at least you can progress from here, and stop ripping your hair out
    Facepalm is much cheaper than engine removal.
  11. #56
    Fwiw, I always smear a thin film of goop around the oil feed hole on the gasket - helps remind you to place the gasket correctly over the oil supply hole on the block.
  1. 18R-C Rebuild. Cost of basic rebuild?
    By LT2K in forum Tech and Conversions
    Last Post: 19-02-2012, 05:59 PM
  2. 1JZ Oil Pump Priming after rebuild?
    By MX83GT in forum Tech and Conversions
    Last Post: 07-09-2010, 07:56 PM
  3. Toyota Hilux 98 3RZ - Fuel Pump Not Priming
    By sash78 in forum Tech and Conversions
    Last Post: 27-11-2009, 07:08 AM
  4. where to get a 2t mechanical fuel pump, or rebuild kit- sydney
    By Cob604 in forum Tech and Conversions
    Last Post: 03-12-2008, 12:45 PM
