Results 31 to 45 of 56
Thread: Priming Oil Pump following rebuild
    Default Re: Priming Oil Pump following rebuild
    Hey Roundy where abouts in nsw are you?
    Before you start pulling it back down, if your close by i can come have a look.
    Cheers Craig
    Was drip feeding it by the filter location on the Gen 2 (now has an oil cooler adapter)
    Craig, I am in Blayney, near Bathurst.
    Would really love to avoid pulling it out, for obvious reasons...
    27.90s @ Esses Hillclimb
    Bugger bit far for me to drive.
    Have you tried the compressed air that i told you about before? I had to do that one on the last motor i did.
    Got no compressor, sounds like a good trick to me!
    Basher Grease Monkey
    Feb 2007
    Take spark plugs out,take oil filter off,crank over engine to see if oil is being pumped to filter and see which way the oil the oil will flow through filter as oil filters fitted with an anti flowback valve will only flow one way,and could cause these symptoms if the filter adapter is flowing the wrong way.
    Scott
    coronacoronacoronacorona
    silly q - but did you bench test the oil pump before you put it back in? Anything you pull apart like that should be tested before re-installed......
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Quote Originally Posted by Roundy View Post
    whoa! how do you build a motor without a compressor? i stop for the night when the air runs out and its too late to wake the neighbors by firing it back up! compressor basically runs flat out when engine building...
    any luck with this yet?
    Never late in an x8
  8. #38
    Administrator Backyard Mechanic
    Jul 2009
    ^^ Why would you use air tools when everything has to be torqued?
  9. #39
    air tools are handy for dismantling but i'd never use one for reassembly.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  10. #40
    who said anything about air tools?
    its all about working CLEAN
    Never late in an x8
  11. #41
    Found the problem, some idiot (me) put the head gasket in back to front and blocked the oil passage to the head...
    Got oil down the bottom, nothing up the top...
    fuck
  12. #42
    Ah shit! I had a feeling there was something majorly askew.
    I'm surprised it didn't build up pressure if it was blocked, or was the oil draining back to sump?
    Are you replacing the gasket? Either way make sure you prep both surfaces properly again
    Never late in an x8
  13. #43
    Definitely replacing the gasket, silly not to.
    Wasn't thinking about the surfaces, is that really necessary?
  14. #44
    i think you'd be safe to not have to do much to either surface as the gasket was never heated and engine ran so it won't have done it's job. Obviously though have a good look over both faces to make sure there is nothing still stuck on.
    BTW - how the smeg did you put the HG on the wrong way?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  15. #45
    Jan 2011
    Yea, good question, ud think the head bolt holes wouldnt line up??
  1. 18R-C Rebuild. Cost of basic rebuild?
    By LT2K in forum Tech and Conversions
    Last Post: 19-02-2012, 05:59 PM
  2. 1JZ Oil Pump Priming after rebuild?
    By MX83GT in forum Tech and Conversions
    Last Post: 07-09-2010, 07:56 PM
  3. Toyota Hilux 98 3RZ - Fuel Pump Not Priming
    By sash78 in forum Tech and Conversions
    Last Post: 27-11-2009, 07:08 AM
  4. where to get a 2t mechanical fuel pump, or rebuild kit- sydney
    By Cob604 in forum Tech and Conversions
    Last Post: 03-12-2008, 12:45 PM
