We're talking about this one right?
The pulse division is meant to be like this:
not like the way that manifold has it. Minor issue.
The big issue is, the gas comes out of cyl 1 or 4 and goes around the bend to the collector thingo, then where does it go? make a hard upward turn to the turbo or take the easy way out and just keep following it around to number 4/1? As far as I can remember the 2/3 collector bit had a nice radius forcing the gas up toward the turbo. Not that I've seen but mate tells me a real HKS cast manifold looks like a philips head screwdriver when looking from the turbo flange. Has a nice radius directing the gases to the turbo.
I don't doubt its strength but it's not designed, uhhh, I mean copied well.
The FC RX7 injectors are 550 cc/min but they don't spray fuel well. You can use them but they are not ideal. What the injector should be doing is providing a finely atomised fuel vapor that's equally spread. This gives better intake charge homogeneity and will provide a better and faster burn. To counter this you sometimes have to dump the fuel in so that even if the fuel is not evenly distributed throughout the combustion chamber there's so much of it that you can get it to burn decently. But then you start getting into looking at intake swirl, quench pads, wet flow and all.
Cool pictures half way down the page here.
