Results 1 to 15 of 16
Thread: 4AGE - Crank and rods
    Jan 2007
    Somerset (UK)
    Default 4AGE - Crank and rods
    I am sure this question has been asked many times so I apologise in advance.
    What is the recognised maximum revs/bhp for the standard crank and rods. I would like to know the maximums for both the 40mm and the 42mm b/e journal crank.
    Thanks
    Junior Member Carport Converter 4agte's Avatar
    Default Re: 4AGE - Crank and rods
    depends if you are going n/a or forced induction....
    You can run 8000rpm all day, with the occasional blast to 8500rpm if you like.
    If you know the crank doesn't have a lot of miles on it and has no cracks (unlikely) they're good for 9000rpm. Just make sure they have plenty of oil.
    The rods are good for those revs as well, again just make sure the bolts are replaced every time they are undone.
    86 slut Grease Monkey
    glenmore park 2745
    put a astra 16v in her lad
    Jan 2007
    Somerset (UK)
    Quote Originally Posted by 4agte
    Thanks, it is n/a
    Jan 2007
    Somerset (UK)
    Quote Originally Posted by Billzilla
    Does that apply to both the 40mm and 42mm crank and rods?
    Thanks
    Junior Member Backyard Mechanic gixer's Avatar
    I used crower rods, you can buy these for reasonable money, then you don't have to worry about it being a problem unless you pull HUGE rpm.
    Quote Originally Posted by 306rwd
    Thanks
    Yep.
    Best also talk to one of the best 4AG men in the UK though, Richard Macer from Hertfordshire.
    01462-481660
    Been a while since I used that number, I hope it works.
    Just a thought but ist torque more so than power that kills the bottom end of an engine so more rpm equals more torque thus rod through the block or piston through the head take your pick?!?!?!
    So high reving n/a puts more stress on engine rather than low reving forced induction?
    Listen to billzilla though i do not doubt his 4age knowledge one bit.
    Nick
    EP82 GT STARLET
    PROJECT CAR AE92 COROLLA 4AGTE - Comming soon
    New Zealand
    for a new prepped crank, 9500 is doable, but more for a race engine thats getting rebuilt or crack tested every season,
    otherwise 8500 would be my suggestion.
    99.9% of 4age failures are usually traced to lack of oil in the bearings
    is the crank more stressed in a boosted engine than an atmo? I thought the inertia of the piston outweighed the downward force of the pressure.
    Jan 2007
    Somerset (UK)
    Quote Originally Posted by Mr Revhead
    I agree. Lack of oil has caused me to blow 2 engines in a year. This was after about 50 rallies of never even taking the cam covers off except for the occasional rebuild.
    The next engine will be dry sumped.
    and why did this happen, oil surge?
    Jan 2007
    Somerset (UK)
    Almost certainly, yes.
    I have been using the same modified/baffled sump and pick up pipe (conversion to rear bowl) since 1995 with no problems. I have probably done 1000 forest stage miles in two different cars with the same setup. I am driving quicker now and with a morev powerful engine so I think I may be outdriving the baffled sump. Perhaps it has always been just within the limit.
    I am definately going dry sump now which will cure the problem.
    do you think someone such as myself that would do some hard street cornering and a racetrack outing at times be well off by adding extra baffling?
  1. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  2. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 10:42 PM
  3. Whats in common with a 20V 4AGE and a 'small port' 4AGZE ?
    By nick.parker in forum Tech and Conversions
    Last Post: 25-01-2006, 11:11 PM
