Results 46 to 57 of 57
Thread: HELP - how to wire up a fuel pump
  1. #46
    Exclamation Re: HELP - how to wire up a fuel pump
    Hi people ...
    Ok, i got the 87a sussed, silly me ...
    I was looking at the diagrams and fired up turbocad and think i got the
    pins worked out when it was mentioned before when they weren't quite right.
    if theres anything not quite right let me know and I'll edit the image.
    cheers.
    Edit: march 19.
    image deleted. neither circuit works in my car . checked and double checked.
  2. #47
    FRustrated INdividuaL !! Grease Monkey Rosey's Avatar
    Default Re: HELP - how to wire up a fuel pump
    Quote Originally Posted by sillycar chick
    Next Question:
    The diagram I have drawn up shows an inline fuse between the battery and the relay. THis is the only way I know how to do it. But, I already have two wires with fuses hooked up to my battery terminal. One is for for my headlights (I dont know why they did it like this but I dont know how to fix it/have been lazy) and one for my amp. If i hook up the fuel pump that will be three. Soon I want to hook up a thermo fan... then there were four.... and the list goes on....
    Is there a way I can set up my own fuse panel hidden in the engine bay so that I can have one wire to the battery terminal and run all the relays from this panel? it seems like the obvious solution but I dont know how to go about it....
    Dana I found what you are looking for in a truck shop in Ipswich the other day if your still interested. Give us a holla .
    Cheers Rosey [email protected] Rosey's GT TA22 Celica - 72' Model
    Quote Originally Posted by TheToyman75
    For me its the 1st generation GT's I'd Kill for a 72 GT but since most people don't even believe they exist
  3. #48
    Cool! Do you know how much they were?
    Im trying to save up to fix critical things on my car(s) at the moment i'll grab the details when i get around to it
    Toyota Car Club (Qld)
  4. #49
    I think I saw $21 for an 8 fuse holder with one battery in.
  5. #50
    I ordered I similar thing from an auto store down the road today, Its a Narva fuse block (blade
    type) Cat no 54430, $18, one heavy battery in 6 outs and rated to 30amp. they have the 8 out
    as well for a few $'s more.
  6. #51
    have a look at ashdowns website
    ashdowns is a well known shop for electrical supplies in sydney
    i have bought 5 and 10 fuse fuseboxes
    the 10 fuse ones have 5 for batt and 5 for ign
    i use these for most older cars
    for newer cars i use some from painless which are 15 or 18 fuses
    beware of some fuseholders like narva they have the spade terminals on the side
    they are ok but for no hassle down the track i alsways like fuseboxes with wires coming of the terminals
    i do not like the slip on terminal type
    they are ok for most jobs but if any terminal gets sloppy then i get bad connection then u get phones calls and whinging
    but if anyone is interested i can order a bag of fuseboxes from ashdowns
  7. #52
    Nice work mate looks the goods now, I will be installing these ideas over the weekend.
    +rep
    THANKS FOR THE GOOD IDEAS...
    Quote Originally Posted by mike1980ra40
    Hi people ...
    cheers.
    Edit: I have revised my diagram (based on witzl's) and the only difference is that pin 30 and
    87 (2nd relay) on mine is the other way around coz i thought 87 is out and 30 is in, thats
    all. While i was at it I added warriors idea for a starter booster at the same time. thanks to
    rosey for pointing something out too
  8. #53
    Hi people, I followed the fist diagram that timbo was explaining, to the letter.
    problem with mine is when IG is on pump is pumping and when the engine is on
    and oil pressure is normal the pump switch's off. then engine stalls. so the diagram
    works well only its backwards on my car.<scratch head>
    I'll double check what I've done later on tomorrow, I've probably got a wires somewhere backwards on the relays.
    cheers.
    edit. see post above. tried the first diagram by timbo, no joy.
  9. #54
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    Hey guys, i think the problem with this system is the standard oil pressure sender is grounded at no pressure and as the pressure rises so does the resistance to ground. So thats why things are going in reverse. Unless ive missed something totally??
  10. #55
    +rep for that one hey ....
    That makes sense hit the nail on the head i think. theres something to work on. cheers.
  11. #56
    I found this the other day, seems like it might be a better option and something worth looking
    into. bosch VW fuel pump relay.
    http://dinsen.net/murena/electrics/fuelpump
    cheers.
  12. #57
    GT4 Freak, and Conversion King Squid's Avatar
    Quote Originally Posted by Celica_73
    Why not tap off the wire to your radio that turns it on with the Ignition. They all end up at the same point.
    As for the wiring diagram that should work.
    If you wanted to get fancy you could modify the wiring and make it a latching relay with a momentary switch. Meaning once the car is turned off you would have to Push the button again to start it. (Self enguaging)
    Sorry no one else seems to have commented on this.
    You are a bad man, why would you hook something up to the inncorrect wire, when connecting it to the correct one is in reality no harder. This is going to create a problem for someone diagnosing the problems in your car down the track, it could also mean that you need to use an incorrect fuse to get both working.
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
  1. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  2. VL fuel pump making strange noises and fuel lines rattling
    By phrostbyte in forum Tech and Conversions
    Last Post: 11-02-2006, 11:04 PM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
  4. Replies: 1
