Results 31 to 45 of 57
Thread: HELP - how to wire up a fuel pump
    Default Re: HELP - how to wire up a fuel pump
    Ok thanks that sounds easy Next question: do you have a catalogue number for one from Jaycar? My book is at home and I cant find any on the net... just wanna look it up before I go there.
    Toyota Car Club (Qld)
    supacrap.... dick sniffs... supersteep... haha, we're such a funny bunch! one could see a potential new thread opportunity here!
    Sounds like you've got things sorted 51lli, good suggestions oman and the rest!!!
    I'll go back and edit that picture that has the two pins accidently screwed up on it, just incase someone doesn't read the rest of the thread. Thanks Mos!
    Hmm...is it strange to get turned on with all this creative backyard electronics?
    Quote Originally Posted by timbosaurus
    Nah, I wont think youre strange, I get turned on every time I look at my engine... it looks HOT as one of my chicky friends said!! LOL!!
    I get that's the difference between a mechy eng and a lecky eng
    Just Another Part Time Grease Monkey
    The suggested wiring diagram based on the pressure switch is good, but the klakka type low pressure fuel pumps used for the carby systems have low current draw (as opposed to EFI anyway). Therefore two relays might be overkill for the pump
    Firstly I would want to make sure the coil has a relay before I would be concerned about having an extra relay for the fuel pump so that you will get a stronger spark. If the coil has a relay then using the original power for the coil (now used to activate the coils relay) should be sufficient for the fuel pump relay associated with the oil pressure switch.
    You will need to fit a second oil pressure switch which forms a closed circuit when the pressure comes up so a T-peice will be required as well. The oil pressure switch is your best option as it will outlast the LPG safety switch many times over.
    Last edited by BrianRA23; 27-05-2006 at 08:41 AM. Reason: Was poorly wrtteen due to 2 one year old babies climbing over me hitting the keyboard
    Hi Brian, i'm not sure exactly what you mean. What are the "cabs" you speak of? and when u say coils, are you talking about the ignition or relay coils?
    The main problem i see with the system we have been speaking about is the oil sender. I'm not sure how many have the output of 12 volts on (engine running) and 0 volts off (engine stopped).
    oil sender catalogue should have those details timbo. And brian, I think i have an idea what your talking about, though your english needs to extend beyond the 3rd grade. Please ensure your spelling is correct (are you talking about Carbs??) and your sentences are structured logically.
    Klakka pumps generally draw a few amps, which is still reasonably significant on a 10A relay. The relay coils generally draw a couple of hundred milliamps. Running a relay for your coil's power is always a good idea, but your confusing the wiring terribly, and it starts getting messy if you dont do it this way from scratch. I would say only wire in what you need to run the things you are adding. Dont forget to upgrade your alternator, as the combination of thermos, halogen headlights, electric pump, amp etc etc will all start to overload your alternator's massive 35A output and cause it to go the way of the dodo.
    Good luck
    Oman
  8. #38
    Sorry for my previous poorly written post - it has now been changed to hopefully make it more readable. I had a one year old girl sittting on my lap hitting the keyboard and the mouse pad while being written.
  9. #39
    Quote Originally Posted by mrshin
    I don't really see how letting the pump run for 2 seconds when you turn on the key is really such a serious issue though.
    might actually be a good thing if its a carby motor, letting the fuel get to the motor before you try and crank it....
    I run mine off its own relay straight off the battery triggered by ignition...dangerous i know if i crash...however your regulator and return line negate any excess fuel flow...so i am failing to see a reason for putting this poor girl through so much heartache to set up a simple fuel pump....I can lend a hand setting it up if you want...is rather easy. You'll need to PM me though.
    Blake
  10. #40
    Oman,
    Was about to cut wire on back of fuse panel to tap in fuel pump then thought hey, what are these two things poking out with plastic over them? Turns out they were male connection tap out point thingeys, so didnt need to cut anything, just plug a wire on
    And I had a look at the fuse panels at supercheap, none of them have a joint connection down one side or an easy way of putting power all down one side without connecting each fuse individually to power. Where can I get one of these fuse panels that I can easily run power down one side with one wire??
    The thing is up and running anyway, just have 3 fuses going to the battery terminal, its getting rediculous and I just wanna tidy it all up!!
  11. #41
    Quote Originally Posted by sillycar chick
    WES Components have this, part number AFB400:
    Accepts 6 fuses, connected together on one side, with a 30A cable and large ring terminal. Should be what you're looking for but I'm not sure how you would get it in Qld.
    Try:http://www.wescomponents.com/
    HTH.
    Mos.
  12. #42
    Thats what i need aswell. Could you run more than 30A through it?
  13. #43
    Yeah I need one of them but the website doesnt tell me how much it is or where I can get one.
    Does anyone else know where in Qld I could get something like this?
  14. #44
    The cable that connects to it is rated at 30A, hence the 30A rating. There is no reason you couldn't add another 30A cable to one of the blank crimp connections and join the two at the battery terminal - the busbar should have no problems with that.
    IIRC $10.95 and there are a few phone numbers and contact details either on that page or at most one click away
    No idea about a Qld branch.
    Mos.
  15. #45
    Nah, i just can't explain myself very well.
    You can simply use a standard 5 pin relay, probably not expensive at all from super steep auto.....................
    +rep for this, this is something i need to do as well ...
    one quick question,
    with the relay thats on the fuel pump (bottom one) whats 87a going to? (it's going to X ?)
  1. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  2. VL fuel pump making strange noises and fuel lines rattling
    By phrostbyte in forum Tech and Conversions
    Last Post: 11-02-2006, 11:04 PM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
  4. Replies: 1
