Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 79
Thread: cam profile mod gains
    Feb 2012
    Australia
    Default Re: cam profile mod gains
    I was just guessing =P I figured the less space between the valve and bore wall the less flow... hehe.
    NooB 3TGTE swapped RA40
    ✨Rahgo2:Turbo Boogaloo✨
    May 2006
    Selangor
    Quote Originally Posted by J-M kujala View Post
    Depends. There is different springs/age and different km:s behind them
    Weakest double springs was 17kg at intake side !! What i have measure. Up to ~30kg (seat pressure)
    Can please let me know how to measure the spring force?
    VAASA / FINLAND
    Quote Originally Posted by metcap View Post
    Just buy a valve spring load test bench. Or weight scale what is made to use in that purpose with hydraulic press or with bench drill.
    Classic personal weight scale can use also, but usually had to add some sheet metal over scale to stop bending the scale cover.
    Rates are measured install height, and open. = install height + lift.
    To that 2TG valve clearance to bore, its faaar away... There is squish ;-) like ~5mm. And with same size bore than combustion chamber, the valve is in angle, so its not cut flow. 2valve real hemis always accept as big as possible, but if that needed, depends at some other things also. With stock intake ports.. No needed.
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    May 2006
    Selangor
    Hi Mate,
    Sorry for the late reply, I have the specs now.
    Spring height 1.85”
    OD of Outer spring 1.325”
    ID of inner spring .710”
    Seat Pressure 1.650:65 & 1.530:95
    Open Pressure 1.160:220 & 1.100:240
    Coil Bind .895
    V.S.I Shim 302
    I hope this helps.
    Ok guys here are the spring specs I got from Sleeka Spares, what does it all mean?
    VAASA / FINLAND
    Spring height in inches & rated pressure Lbs
    A lot stiffer than stock ones,
    - IQ 1.0 -09
    - Lexus IS250 -06
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    What that means is RR4's, 310lbs/inch as in the best springs for 2tg/3tgeu/3tgeu.
    Don't bother with any others they are the shizzle or go look at other specs if you like...
    Jun 2006
    Camshaft duration is all about the Lift @ Duration not the "Advertised duration"
    If you look at charts of Lift/Duration you will see the difference.
    Will leave it at that.
  8. #38
    May 2006
    Selangor
    Ok I understand spring height but please explain Seat Pressure 1.650:65 & 1.530:95, Open Pressure 1.160:220 & 1.100:240
    And excuse my dumbness but what is RR4?
  9. #39
    Jun 2006
    It's a part number of performance springs.
    Have sussed out other spring manufactrures "but to no avail"
    Means as you say:
    1.650"inch at 65 lbs per inch
    1.100"inch at 240 lbs per inch
    What is your cam lift?
    0.400"?
    0.410"?
    0.420"?
  10. #40
    Jun 2006
    Lets just say RR4's are great lb's / inch and good coil bind rate.
  11. #41
    VAASA / FINLAND
    This calculator give good info ... just need to know all these details...
    http://dairally.net/daihard/chas/Mis...alveSpring.htm
    - IQ 1.0 -09
    - Lexus IS250 -06
  12. #42
    oregon
    Quote Originally Posted by andrew_mx83 View Post
    ive never seen the logic in using oversize valves unless the seats are bored out or replaced with larger ones to suit. as you say if anything OS valves on stock seats would seem to impede flow.
    In a 4AGE you will get one advantage using O/S valves on machined, but otherwise stock seats.... the first .100" of lift you will SUBSTANTIALLY improve flow... but the advantage goes away quickly.
    The reason you can't just open up a stock seat to O/S specs is there would not be enough seat left for the head to retain. It would be likely that the seat would not last.
  13. #43
    Junior Member Backyard Mechanic gixer's Avatar
    Quote Originally Posted by oldeskewltoy View Post
    don't forget the head has to be capable to flow...
    A stock head will often hit a wall where it just stops flowing more... So cams only tell part of the story.
    for example... 4AG head... without proper porting, there is little reason to run lifts much above stock, but with proper porting....
    Well said, I have flow benched many 4AGE heads, 16v and 20v, when selecting a cam, the first thing I do is flow bench the head, no point putting 11.00mm lift cams in, if the head runs flat at 8.00mm, once I have got the lift worked out, then it's onto the duration depending on what sort of rev range is required.
    It amazes me how many people port their heads without doing a before and after on a flow bench, it's rare I see someone do a before and after and actually get a gain, some heads look awesome but flow worse than standard.
  14. #44
    Melbourne Victoria
    i go for more lift if its shim under and stay around 250 to 260 duration at 50 thou ,cams with to fat a nose are getting up there any cam after 265 duration at 50 thou is going on full race cam
  15. #45
    oregon
    Quote Originally Posted by gixer View Post
    I have to admit I don't do it all the time...
  1. PK belt profile??
    By TERRA Operative in forum Tech and Conversions
    Last Post: 01-06-2009, 08:04 PM
  2. Cam Profile - Regrinding
    By kylestyleup in forum Tech and Conversions
    Last Post: 26-01-2008, 01:51 PM
  3. age in publie profile
    By Xistant in forum Toymods Car Club Membership and Feedback
    Last Post: 18-05-2006, 04:13 PM
