Page 6 of 6 FirstFirst ... 456
Results 76 to 79 of 79
Thread: cam profile mod gains
  1. #76
    oregon
    Default Re: cam profile mod gains
    Quote Originally Posted by metcap View Post
    those numbers are for the 2tg stock cams?
    apologies... those are for 4AGE....
    these are for 2TG...
    2T-G Engine
    4cyl in-line water cooled, DOHC
    Bore & Stroke => 85mm x 70mm (1588cc)
    Compression Ratio => 9.8:1
    Ouput => 124hp @ 6400rpm (SAE gross)
    Torque => 113ft/lb @ 5200rpm
    Compression Rings => 2
    Oil Rings => 1
    Intake Valve Opens (BTDC) => 20 deg (16 deg from April 1973)
    Intake Valve Closes (ABDC) => 48 deg (60 deg from April 1973)
    Exhaust Valve Opens (BBDC) => 52 deg (60 deg from April 1973)
    Exhaust Valve Closes (ATDC) => 16 deg (16 deg from April 1973)
    Firing Order => 1-3-4-2
    from here - http://www.toymods.org.au/forums/tec...-diagrams.html
  2. #77
    May 2006
    Selangor
    Quote Originally Posted by oldeskewltoy View Post
    Thanks a lot for pointing it out, great info. So according to the factory manual the 222 head and above cam specs are 256/256 with 10.27mm lift and 32deg overlap.
  3. #78
    Low rep Grease Monkey
    Apr 2010
    bkk
    which engine are you asking about?
  4. #79
    May 2006
    Selangor
    ok I just timed my 2tg 222 head+cams and I got the total duration at 1.27mm(50 thou) is 261deg, so why is it different from the factory specs?
  1. PK belt profile??
    By TERRA Operative in forum Tech and Conversions
    Last Post: 01-06-2009, 08:04 PM
  2. Cam Profile - Regrinding
    By kylestyleup in forum Tech and Conversions
    Last Post: 26-01-2008, 01:51 PM
  3. age in publie profile
    By Xistant in forum Toymods Car Club Membership and Feedback
    Last Post: 18-05-2006, 04:13 PM
